Thread: Help!! car running Rich low MPG Diagnostic report inside
    london
    Default Help!! car running Rich low MPG Diagnostic report inside
    Hello any one out there who knows about these readings can help me.
    I am getting 15mpg round town london and 30 on the motor way using shell normal fuel i get 31mpg using shell ultimate.
    car is signum 2.2 direct petrol
    seems some thing is wrong i cleaned manifold, throttle body, o2 sensor thats in the Cat, and also the one thats in the intake manifold and egr (egr and high pressure fuel pump is new).
    so would like some one to check these readings and point me to the stuff thats need fixing or changing .
    I do not get any fault codes when scan.
    here is the readings that show car is running rich
    Identifier: 0x0601
    Motor type: Z22YH
    Measuring blocks information:
    B1S1 O2 Sensor Heater (Bank 1 Sensor 1),Active
    B1S1 O2 Sensor (Bank 1 Sensor 1),1.484 mV
    B1S1 Air/Fuel Ratio (Bank 1 Sensor 1),Rich
    B1 O2 Sensor Loop (Bank 1),Closed
    B1S2 O2 Sensor Heater (Bank 1 Sensor 2),Active
    B1S2 O2 Sensor (Bank 1 Sensor 2),762 mV
    B1S2 Air/Fuel Ratio (Bank 1 Sensor 2),Rich
    B1 Short Term Fuel Trim (Bank 1),-1 %
    Catalyst Protection Enrichment (Bank 1),Inactive
    Full Load Enrichment,Inactive
    Desired Engine Idle Speed,738 RPM
    Idle Speed Modified,NO
    Idle Speed Offset,Inactive
    Vehicle Speed,0 km/h
    Battery Voltage,13.7 V
    Ignition Status,On 12V
    Main Relay,Active
    Starter Relay,Inactive
    Engine Speed,756 RPM
    Fuel Pump Relay,Active
    APP at Idle Position (Accelerator Pedal Position),Active
    APP Sensor 1 (Accelerator Pedal Position),0.96 V
    APP Sensor 2 (Accelerator Pedal Position),0.47 V
    APP Sensor 1 Learned Lower Position (Accelerator Pedal Position),0.97 V
    Calculated Throttle Position,3 %
    Throttle Position,Idle
    TP Sensor 1 (Throttle Position),0.51 V
    TP Sensor 2 (Throttle Position),4.47 V
    TP Sensor 1 Learned Lower Position (Throttle Position),0.34
    Throttle Position PWM Servo Signal,93 %
    Mass Air Flow Sensor,0.64 V
    Mass Air Flow Sensor,10 kg/h
    Intake Air Temperature,38 °C
    Intake Air Temperature,1.27 V
    Manifold Absolute Pressure,1.02 V
    Knock Control,Inactive
    Desired Fuel Pressure,5.000 kPa
    Fuel Pressure Feedback,4.976 kPa
    Fuel Pressure Feedback,1.6 V
    EGR Valve (Exhaust-Gas Recirculation),Active
    EGR Position Feedback (Exhaust Gas Recirculation),0.84 V
    EGR Position Commanded (Exhaust Gas Recirculation),0 %
    EGR Pulse Ratio (Exhaust Gas Recirculation),40 %
    Fuel Tank Ventilation Valve,Active
    Fuel Tank Ventilation Valve,38 %
    Swirl Level Control Solenoid Valve Pulse Ratio,18
    Jan 2010
    glasgow
    15mpg? thats way low bud im getting around 23-27 mpg and on a run near 40 u say u cleand the 02 sensors? with what? as u can kill the sensor cleaning it can u smell petrol? wen was the last time u gave the car a service put new oil and filters in and plugs and wen the old oil is out smell it see if it stinks of petrol? im sure some 1 on here will tell u if the settings are correct failing that try a compresion test
    preston
    Smile
    have a look at this thread
    http://www.vectra-c.com/forum/showthread.php?t=115169
    maybe your answer may lie within these comments
    Regular Member DaveW555's Avatar
    Cannock
    Interesting one this, normally I'd say its the lambda sensors causing the problem but looking at the diag report it looks like they're doing what they should be as long as they're switching (voltage fluctuates high to low etc), Also I would usually say that the air mass could cause rich running but you haven't got a fault code to suggest this (unless it is on its way out and not flagging a code yet of course) discount split pipes as they would make it run leaner rather than rich. I think like hoochy says first thing would be to do a full service, change the fuel filter, oil and filter, air filter and plugs, might be worth sticking some injector treatment through it as you may have a sticking injector that is pulsing for too long therefore injecting too much fuel, examining the plugs should give you a good indication of what each cylinder is running like.
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
    old oil is out smell it see if it stinks of petrol? what does that mean because mine stinks of petrol when i take the filler cap off.?????
    london
    hi i clean o2 sensor with 100% alcohol,
    Will jump from rich to lean after engine is warm
    is always stuck on rich
    Is this normal?
    car has new filter, new cam chain. new oil 10-40 semi magnatec. (new spark plugs bought for dealer . GM brand)
    the car is also a bit lumpy on idle
    ill smell the oil tomorrow
  1. Car's running RICH *HELP*
    By Mark Evison in forum Insignia Troubleshooting (READ ONLY)
    Last Post: 7th August 2012, 22:22
  2. Running rich ?
    By tosh23 in forum Engine & Drivetrain
    Last Post: 17th August 2011, 21:31
  3. U480 diagnostic Scanner, can engine be running when reading codes
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2010, 11:58
  4. 2.2DTi running rich ?
    By Daywalker in forum Engine & Drivetrain
    Last Post: 19th September 2009, 13:25
  5. OBDII Car Running Diagnostic Data Recorder
    By Diet1985 in forum General Chat
    Last Post: 29th August 2009, 21:44
