Thread: emission light
    norwich
    Default emission light
    hi all i have a vectra c 53 plate 1.8 petrol club and the emission light came on and stays on while im driveing what does it mean and is it same to drive
    please help cheers
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Sounds like an issue with one of the 2 lambda sensors. Mine comes on randomly too, mine has been diagnosed as an issue with the 2nd Lambda. Maybe someone here can tell me(us) the reason for 2 Lambda sensors.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Emission light could refer to anything that affects the fuel efficiency.
    Anything from a sensor, to a poorly fitted plug (don't laugh, this happened on my friends 2005 Astra petrol).
    Ideally, you need to get the DTC's (trouble codes) read with any suitable code reader.
    If you know someone with tech 2, Op-Com, Vaux-com then they could clear the trouble codes. Then re-scan for problems,
    Without finding what is causing the light to come on, you can't really speculate on how to fix the problem.
    DERBY
    hi I have a 2003 2.2 sri ,on sunday after filling up, my emission light came on , ive read the code and I have p0141, rr o2 snsr , has anybody had this code , and if I change the snsr will this cure it , theres a breakers near me at sandiacre ,they have 3 sri's so I might try a second hand snsr first , although Ive seen vauxhall ones on the net for £38 so not a fortune but want to ensure it will cure the code , ive cleared the code driven it and then when I call up DTC's it says one pending p0141 but doesnt show emission lamp on dash , I may run the fuel out first before changing the snsr to see if this has any effect
    Regular Member fifesri's Avatar
    Sep 2009
    Fife
    Sharper.,, check out the other emission light thread by me which should be visible somewhere , I had the same issue but mine went out today !!!
    DERBY
    fifesri thanks for the reply strange thing is I put in £40 worth of Asda petrol in sunday and within a couple of miles the lamps on , makes me wonder , I will run it out and refuel with a better brand next time ,
    Sep 2009
    Fife
    Makes you wonder if ASDA's reputation for crap fuel is true !! Like I said in the other thread, proper Shell unleaded and some redex and the light went off. The Mrs is still at work but am hoping bthe light stays off on her road home !
  1. spanner light reset emission light now on HELP!
    By johnny boy67 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 12:07
  2. Emission light on.
    By ExclusivDoug in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 10:36
  3. emission light help!
    By platty in forum Engine & Drivetrain
    Last Post: 22nd August 2008, 18:09
  4. help with emission light
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 10th July 2008, 02:02
  5. emission light
    By pipamish in forum Engine & Drivetrain
    Last Post: 20th March 2008, 08:29
