Thread: n/s/f wheel bearing gone
    Regular Member mikeeaston's Avatar
    widnes
    Default n/s/f wheel bearing gone
    hi all
    my n/s/f wheel bearing is whining it's t*ts off i have emailed vauxhall through car parts connextion and they have got back to me and said that the part number is 93186388 and they also want 170 + vat for this item
    just wondering if there is a difference between the n/s and the o/s as i have found one on ebay with part no 93186387 and i am unsure if this one will fit
    http://cgi.ebay.co.uk/Vauxhall-Vectr...item35aa219c54
    hope u can help thanks
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Mike
    on autovaux order form it just lists front bearing petrol or diesel so it looks like they are not handed,(the diesel is about £10 /£12 dearer than petrol)
    preston
    Wink
    try lmf vauxhall
    www.lmfvauxhall.co.uk
    they should be more realistic
    r u sure its a bearing? before you part with any money get it checked out
    cheers
    widnes
    Quote Originally Posted by mparks8590 View Post
    cheers
    i cant see it being anything else it is whining loads and when i turn right and put more pressure on the n/s it gets worse i have checked and there is no play in the bearing put i just cant see it being anything else, any ideas
    thanks guys
    PRESTON
    EPC lists 93186387 for cars built between 2003 and 2004 (except IDS) whereas 93186388 is for all cars built after 2005, (or those with IDS between 2002 and 2009)
    preston
    are your dust sheilds rubbing?
    just a thought, but would usually be more like brake squeal
    sounds like bearing but i'd expect play
    another thing
    are both front tyres new. if not swap them to rear and see
    worth try for no cost
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Best way to check is to jack the wheel up and roatate it, then do the same with the other side, if a bearing has gone you'll feel the difference.
    It is normal for the Vec to not have any play in the bearing but still whine, this is due to its "sealed" constuction
  1. UJ or wheel bearing?
    By Endricks in forum Engine & Drivetrain
    Last Post: 8th April 2012, 10:49
  2. Wheel Bearing ?
    By jer75 in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2011, 02:01
  3. wheel bearing
    By stuart bigboy in forum Suspension, Wheels & Brakes
    Last Post: 28th October 2007, 17:07
  4. Wheel Bearing with VX?
    Last Post: 6th March 2007, 00:19
nsf wheel bearing
