Thread: Power Steering Warning
    Regular Member multi's Avatar
    Jan 2008
    east anglia
    Default Power Steering Warning
    Hi folks
    Have just unfortunately had the power steering warning light come on in my 1.9cdti (150). The stereo started to go on and off before the warning light came on. Also the abs and t/c lights came on and shortly after went out. The power steering then gave up, luckily I had stopped. Then tried stopping and starting the car with power steering working ok for 30 seconds before all the same lights came back on, and the steering giving up once more.
    Its seems as though it could be an electrical issue as the power steering returned (briefly) and the reservoir is full, but if someone could clarify this for me I'd be most appreciative. Has anyone else had a similar problem or can anyone shed any light on what it might be and how much its going to cost me at the dealer.
    Thanks in advance
    Regular Member Exclusive BV's Avatar
    West Midlands
    I think it's your alternator matey
    (or the wiring loom between the alternator and battery)
    Sounds like your electrics arent getting the juice they need
    preston
    Wink
    yes i'd concur
    make sure you get your battery checked out too.... most indy car shops will test for free.
    cheers
    PRESTON
    agreed, most likely alternator, have it checked to see that its putting out at least 14volts and that the battery is accepting charge.
  1. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  2. power steering warning light!
    By mick 1986 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2010, 20:36
  3. Power steering warning light
    By neil1194 in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2009, 09:53
  4. Power steering warning...
    Last Post: 26th December 2008, 17:55
  5. Power Steering Warning Light - Ugh!
    By Leviathan in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2008, 17:25
