Thread: Caliper carrier question
    Sodding Typical on Sea
    Default Caliper carrier question
    I need to ask those who know.
    In my Saab the 9-5 Aero had a 308mm disc the other models had the 286mm disc from memory.
    The calipers from ATE were identical regardless but the carrier was the only different item.
    Can I do this to my car? can I buy the carrier?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Not from the 9-5 mate as they won't fit the Vec, it's the 9-3 thats the same
    Thats what I was getting at, if all I need is a carrier what one? as the 9-5 is more akin to a Vectra-B chassis I know so doesn't cross over.
    Has anyone done this job and can I buy the carrier from a dealer?
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by Derek Mc View Post
    Are you using the 9-5 as an example, where you can switch carriers but keep the same caliper, rather than asking of 9-5 brakes will fit the Vec-C? If so, the answer is still no unfortunately; all the calipers (285, 302, 314 & 345) differ - it's not just the carriers that are different.
    Oh drat!!!
    It was the 9-5 as an example, I wondered if I could use my vectra caliper and a larger carrier to fit a 314mm.
    Dag Nabbit!!!!!
  1. caliper carrier bolts
    By maximus1267 in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2016, 16:39
  2. Cleaning caliper carrier
    Last Post: 26th September 2012, 22:59
  3. Where to get caliper carrier bolts?
    By shchuka in forum Suspension, Wheels & Brakes
    Last Post: 23rd September 2012, 22:01
  4. caliper carrier bolts
    By trickyjacks.4 in forum Handling & Braking
    Last Post: 19th August 2011, 16:48
  5. Quick q.... Which way do the caliper carrier....
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 14th November 2009, 14:56
vauxhall vectra caliper carrier for sale
