Thread: Error code p0400, EGR help.
    South East
    Question Error code p0400, EGR help.
    Hello!
    The story goes........
    Was working on my 05 plate 1.9 CDTi 150 Signum last night with a friend around the engine bay trying to work out how to remove my faulty Air Con Compressor (worked it out now btw). Anyway, we were having to move things aside (gently, at least I think so) around the front of the engine near the air intake piping to get at certain areas below. Put everything back together again and now my Exhaust ignition gases light is permanetly on (NOT flashing before anyone says about that) and I have a fault code of p0400.
    My thinking is that I have accidently disconnected or knocked loose something to do with my EGR? Anyone got any ideas where to look? I'm planning on having a look myself tonight but tips before hand would be most helpful.
    preston
    Question
    on the 150 1.9 the egr should be on the back of the inlet manifold.
    check the cable going to it
    other than that strip it off, clean and replace
    loads of thread about it and a nice how 2
    anyone any other ideas in relation to the work alluded too?
    West
    check all the vac pipes are connected correctly
    South East
    It's funny you mention this as the VAC pipes were some of the pipes I had to move......... reakon I've disconnected it? In my ignorance, where do the VAC pipes leads to, pictures would be very helpful!
    P.S Thanks for the tips so far!
  1. P0400-f8 fault code
    By leeeager in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2012, 13:08
  2. EGR VALVE error P0400
    By signum_05 in forum Engine & Drivetrain
    Last Post: 26th June 2012, 22:55
  3. p0400-5a fault code
    By swvectra in forum Engine & Drivetrain
    Last Post: 12th July 2011, 06:57
  4. Error code: P0400 - EGR
    By dinac_cro in forum Engine & Drivetrain
    Last Post: 3rd January 2008, 17:20
blad p0400egr opel vectra
