Thread: 345 discs under 17inch SRI wheels
    preston
    Default 345 discs under 17inch SRI wheels
    morning all
    hoping someone out there has managed this
    Managed to pick up some V6 caliper from 314mm setup and was gonna do 314mm conversion but then....... i see courtenay do a 345mm kit which ( it looks like on web ) seems to use the same calipers but i presume uses new carriers from Vxr
    of course i now fancy the 345mm setup
    So question is
    anyone managed to run 345mm setup on the 17inch SRI wheels from the facelift 1.9 sri 150.
    If so did you have to use spacers???
    cheers in anticipation
    WGAF#5
    police spec vehicles run the 345 set up on standard alloys - BUT the clearance is minimal but can be accomplised = the only issue you may have is when you have a dodgy alloy or tyre that needs additional weights as these will probably get knocked off
    If you flick through the pictures here it shows just how close they are...
    You can get them cheaper from Courtneys though, painted blue as well...
    Full Member spennny's Avatar
    Blantyre
    Quote Originally Posted by Penfold101 View Post
    thats close !!!
    Quote Originally Posted by spennny View Post
    thats close !!!
    Just about enough room for a gnats ****...
    18's are a bit safer..
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by mparks8590 View Post
    morning all
    It's not the same caliper shared between the 314 and 345; the pads from the 314 will fit in the 345s but only after some hefty rework. If it was the same caliper they'd fit without adjustment.
  1. What are these 17inch wheels? irmscher??
    By weverall in forum Styling
    Last Post: 7th January 2012, 23:09
  2. 17inch irmy wheels £500
    By m20_swe in forum Parts for sale
    Last Post: 16th October 2008, 22:44
  3. Can you fit 314mm discs to replace discs on back wheels of a GSi 3.2???
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 21:10
  4. 2005 17inch SRI wheels (mint)
    By sri22dti in forum Parts for sale
    Last Post: 31st March 2007, 16:37
vectra 345mm discs under 17
