Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: My New Boot Lights & Rear Footwell Lighting Question...
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Default My New Boot Lights & Rear Footwell Lighting Question...
    Bought couple of these (48cm flexible LED strips), there only a couple of quid for 2...
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=260607181775
    48cm ones are the best size for the location as you only need to cut 3 leds off to fit perfect along and around the curve (once the supports are cut out)... These LED and similar SMD strips can be shortened by removing multiples of 3 from the end due to the way there wired up
    Pictures below:
    QUESTION:... People who have fitted rear footwell led's etc, how did you attach to the underside of the seat. Just a few cable ties or.......
    Cheers, lee
    Sep 2009
    Glasgow
    where did you connect them to, any pics would be helpfull as i have 2 spare 48 strip lights
    Wales, UK
    Would be nice to see a pic of the connection and where you got those strips from ? ^^
    Great job there, looks fantastic ! The standard light is pants really lol, good job
    18 Post(s)
    Mileage : 110k
    Here's my messy wiring to the rear boot light - which i've kept
    48cm ones, if you chop out the supports and cut off 3 from the end they'll fit perfectly here
    If you look at my pics they dont quite go to the end as i had to cut 6 off one, due to the 1st 3 on the other being blown. and the replacement i ordered was a different shade of white when finally turned up...
    But i'd follow the curve if i was you to make it neater. I used a hack saw blade for either side of the supports, and pliers to pull them out... took 2 mins... HTH...
    18 Post(s)
    Mileage : 110k
    Quote Originally Posted by mark_647 View Post
    Link added to 1st post... but if you ebay "white LED flexible strips" you cant go wrong, loads and different ranges in prices... All my chinese ones have turned up in 10 days too and 5 times cheaper then UK sellers
    Sep 2009
    Glasgow
    did you wire both strip light 2 the boot light.
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Im going to do this to the Vec-B, just want to know, what impact will it have (if any) to the standard boot wiring, I mean it wont over heat it will it?
    Last thing I want is wires melting & burning out.
    Also, how did you attach them to the actual panel!
    GOOD JOB THOUGH!
    18 Post(s)
    Mileage : 110k
    Normal wiring will be fine, and i just used double sided foam tape...
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=140374662485
    SCOTLAND
    Superb idea this the standard lighting is rubbish so this will be a huge improvement for so little cost.
    Regular Member johnny kebab's Avatar
    May 2007
    Leighton Buzzard
    I've had two 30cm strip wired in to my boot for about a year after realising the boot like is terrible, I work nights and am in and out of my boot all night so these help a lot, got my glued to the underside of the parcel shelf and have male/female assorted wired in for if I want to remove the parcel shelf for anything.
    JK
  1. Footwell lighting
    By byers in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2012, 00:44
  2. footwell lighting question
    By hadiislam in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2011, 23:19
  3. footwell lighting
    By MiniVauxhall in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2010, 20:02
