Results 1 to 10 of 15
Thread: No Power below 1500rpm
    Regular Member stuart813's Avatar
    gosport
    Default No Power below 1500rpm
    Hi Guys i've got a small problem i seem to have a loss of power below 1500rpm.
    Anyone got any ideas on what could be the cause of the problem.
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Is it a 1.9 by any chance?????
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Let me guess 1.9 CDTI 150? If so it could be the egr valve however I wouldnt say there is anything wrong tbh as this engine generally doesn't have the grunt under 1,500rpm anyway. If the issue is bad enough that pulling away is dangerous then I would say the egr valve is the first port of call as it is a common problem on this engine - if this is the one you have.
    Best it booked in any case.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Nov 2007
    weymouth, dorset
    stockport
    Eek
    Sounds like YET ANOTHER EGR issue!!!!!!!!
    gosport
    Hi Guys yeah it's the 1.9cdti 150bhp have changed the EGR to cure a juddering problem could the inlet manifold do with a good clean????
    Nov 2007
    weymouth, dorset
    Has the swirl flap bar fallen off?? This can cause them to be flatter than usual..
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by stuart813 View Post
    Evenm tough you have cleaned it, it may not be functioning fully tbh. Even if the solenoid moves freely, it still may not be functioning properly.
    Manifold issues tend not to affect the low end performance - only 2,500rpm and above really.
    Gazza4
    gosport
    Swirl flaps haven't checked them recently but were fine a few weeks ago.
    Power is great after 1500rpm
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Most likely the egr valve but again it depends how bad it is as you could be spending money on an issue which doesn't really exist.
    Gazza4
  1. Miss fire at 1500rpm on my 120 cdti
    By rob10 in forum Diesel Engine related
    Last Post: 29th June 2013, 23:37
  2. Very strange noise from 1500rpm
    By ads3 in forum Engine & Drivetrain
    Last Post: 19th December 2011, 22:20
  3. shudder or miss in car up to 1500rpm
    By melvin in forum Engine & Drivetrain
    Last Post: 18th February 2011, 17:38
  4. 1.9CDTI power dip at 1500rpm
    By helisurf in forum Engine & Drivetrain
    Last Post: 13th November 2009, 12:50
  5. cdti 150 engine power below 1500rpm
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2008, 14:15
