Thread: Rounded off sump plug... any ideas?
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Default Rounded off sump plug... any ideas?
    Alright boys? I've got a little dilemma. I offered to help change the oild on my father-in-law's volvo S80 before he goes on holiday on saturday. We got it up on the ramps, found the sump plug no worries. But guess what. It's stuck fast. We've tries allsorts. Anyone got any tips? Oh and by the way..... the bolt head is more or less knackered now!
    Regular Member Martii's Avatar
    wolverhampton
    Oct 2006
    southampton
    15 Post(s)
    I had this with a cotterpin on my sons moped, wouldnt budge for love or money. Pops came round, the bar was about 10mm, he drilled an 8mm hole into it nearly all the way through which relieves the pressure on the outer edge, in your case the thread. Worth a go IMO HTH
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by Martii View Post
    It's a rounded off sump plug!!! Simples
    aberdeenshire
    Try to fill flats on it and hammer a socket onto it (what i had to do). Or try some of those irwin nut extractors
    Norwich
    Trim : SXi
    Engine : 2.2
    Just hammer an old socket on it and twist it off
    Nov 2009
    Norfolk
    Various things you could try.
    Hammer a smaller socket onto it.
    Drill the centre then use a bolt extractor to remove it.
    Weld a nut or an old socket to it then undo it.
    Mole grips are possibly worth a go!
    Regular Member poves's Avatar
    lancashire
    If you can get some plumbers stilson grips on it , that's the way forward - honest.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Cheers for the ideas guys. We're having another go on thursday. I think we're gonna go with a combination of things. Probably gonna start with filing the head into a square and getting a BIG adjustable on the job. Failing that it's 18" stilsens (they're called an 'Englander' in Germany, Sweet!). then last resort. remove sump pan and put it on the workbench. I'll keep you posted.
    lancashire
    I tried everything , and then the stillies were the last resort , they whipped it out a treat - the beauty of them is , the harder you turn them , the tighter they grip.
    Let us know what happens mate.
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Oil leak on my 2.0 T, not sump plug, any ideas??
    By Steve 100 in forum Engine & Drivetrain
    Last Post: 25th May 2012, 11:43
  3. Sump plug rounded off - Help
    By Barlow in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2012, 15:11
  4. sump plug rounded off/wrecked
    By bigben in forum Engine & Drivetrain
    Last Post: 30th April 2009, 21:46
  5. rounded sump plug
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2007, 20:43
