Originally Posted by
Danwells72
Dont know about holding the boost longer but i guess due to the different piping thats possible. WIth regard to spooling, yes you will see a decrease in the lag as when the throttle is released the butterfly valve closes holding the pressure in the pipes and in return sending it back to the turbo, with the dump valve it will release this pressure build up resulting in no back pressure.
EDIT: unless your a big fan of the pppssssttt, i would suggest a recirculating valve as oppose to an atmospheric valve
