Results 1 to 10 of 11
Thread: hesitating - limp mode
    Regular Member madman's Avatar
    nottm
    Default hesitating - limp mode
    the old girl started hesitating a week ago, chucked some millers in but today twice ive been hit by limp mode. could this be the fuel filter , had the EGR replaced a couple of years ago but there was no hesitating then.
    am i being too hopefull of it just being the fuel filter? off to cornwall friday 300 miles so a little worried
    nottm
    anyone?
    preston
    fuel filter unlikely unless
    a) you got water or other contaminants in there
    b) you've got a partially de-pressuired system eg leak
    i' start with EGR clean + boost sensor clean + check your swirl bar connector and it s actuation.
    nothing to lose but a bit of time and £5 on carb cleaner
    bargain if it works
    are you brakes ok?
    nottm
    brakes are fine.
    cheers mate i'll get em checked
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by mparks8590 View Post
    bargain if it works
    are you brakes ok?
    As it's a dti we'll ignore the swirl bar bit.
    Firstly cheack all of the pipes, Vacuum and Boost. The boost pipes on the DTi are made of cheap rubber and do split giving the symptoms you describe.
    If the EGR hasn't been cleaned since you had it replaced 2 years ago I can nearly guarentee it will be coked up and in need of a clean. The boost sensor (due to where it sits) attracts oil vapour and over time this can clog the sensor so clean that too.
    Once you've tried all of the above report back
    preston
    Thumbs up
    how did you work out it was a dti?
    couldn't see anthything in post.
    anyway just hope the corwall trip goes well
    cheers
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    cheers
    It's on his profile page
    preston
    aha
    i just thought you had jedi powers
    added that to my checklist from now on
    I can feel a whole new thread coming on now on a star wars theme
    nottm
    had the egr cleaned at a garage near work. we got to cornwall and back circa 900 miles and only hit limp mode about 10-12 times on some long uphill sections on the a30. gonna check the egr and boost valve this weekend myself. cheers guys
    north east
    Are you getting a flash of the radiator light when limp mode comes in, if so id put 50p on it being the crank shaft speed sensor. clean the egr first as thats free but if the fault remains get the codes cleared and see what gets chucked up.
  1. Limp mode?
    By chrosty in forum Engine & Drivetrain
    Last Post: 18th April 2012, 12:35
  2. Limp mode help
    By neill in forum Engine & Drivetrain
    Last Post: 20th March 2012, 19:53
  3. eml & limp mode???
    By actionman in forum Engine & Drivetrain
    Last Post: 28th February 2011, 13:20
  4. Limp mode again
    By craig2.2 in forum Engine & Drivetrain
    Last Post: 5th August 2009, 21:05
  5. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
