Thread: 1.3 cdti help!!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default 1.3 cdti help!!
    A friend has a corsa 1.3 cdti 05/06 rg and has been told it has a barometric pressure sensor fault or theres a difference in pressures between the turbo & the inlet manifold, vx seem to think the turbo has gone!!, the car drives well and pulls as it always has with no smoke and good fuel consumption, sounds like they are bumping the costs up!, ANY ideas would be greatly appreciated.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    they are proberly right m8 if its got tc of p0108 the turbo waste gate sticks giving you over boost meaning barometric press not plausible with boost press the fix is to change turbo not that expensive i think 150 plus vat hope this helps..
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    thanks for the reply!, he cant understand it cos its running great apart from having the fault light on all the time, im going to put the code reader on it tomoz and see if i can help any!, will try to locate any sensors and do any cleaning required, along with checking wires and vacum pipes,
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Check out the boost pressure sensor first, they are prone to give the wrong readings and give a code of, (boost pressure high pressure), this is because the boost sensor is reading about 10kpa out and gives the ecu a too high reading on boost..
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    done some code reading today and general readings with car ticking over.
    Vehicle VIN xxxxxxxxxxxxxxxxxxxxxx
    Identifier:0x2423
    Total number of fault codes: 1
    P0106 - Barometric Pressure not plausible with Boost Pressure
    (0F) - Present.
    PC based diagnostic tool
    Date and time>,21/07/2010. 15:55
    Workshop information:
    Ursu
    Selected model>,2006,Corsa-C,Engine,Z 13 DT
    Control Unit:
    Keyword #1: EF
    Keyword #2: 8F
    Normal timing parameter set.
    Measuring blocks information:
    Battery Voltage,14.1 V
    Ignition Status,On 12V
    Main Relay,Active
    Fuel Pump Relay,Active
    APP Sensor 1 (Accelerator Pedal Position),0.96 V
    APP Sensor 2 (Accelerator Pedal Position),0.47 V
    Calculated Pedal Position,0 %
    APP at Idle Position (Accelerator Pedal Position),Active
    Desired Idle Speed,850 RPM
    Engine Speed,850 RPM
    Camshaft Speed,425 RPM
    Idle Speed Offset,Inactive
    Idle Speed Modified,No
    Normal Engine Operating Temperature,Inactive
    Coolant Temperature,76 °C
    Coolant Temperature,0.75 V
    Fuel Temperature,36 °C
    Intake Air Temperature,33 °C
    Intake Air Temperature,2.12 V
    Ambient Temperature,18 °C
    Mass Air Flow Sensor,23 kg/h
    Mass Air Flow Sensor,1.67 V
    Barometric Pressure,99 kPa
    Barometric Pressure,3.71 V
    Boost Pressure,81 kPa
    Boost Pressure,1.53 V
    EGR Valve (Exhaust-Gas Recirculation),Inactive
    EGR Pulse Ratio (Exhaust Gas Recirculation),0 %
    Desired Common Rail Fuel Pressure,25.00 MPa
    Common Rail Fuel Pressure,25.60 MPa
    Rail Pressure Control Valve,76 %
    Actual Injection Quantity,5 mm3
    Actual Injection Start,1 °CA
    A/C Information Switch (Air Conditioning),Inactive
    A/C Pressure (Air Conditioning),768 kPa
    A/C Pressure (Air Conditioning),1.18 V
    A/C Relay (Air Conditioning),Inactive
    A/C Cutoff Mode (Air Conditioning),System OK
    Fan Relay 1,Inactive
    Fan Relay 2,Inactive
    Fan Relay 3,Inactive
    Glow Time Relay,Inactive 12V
    Diagnosis Glow Time Relay,Inactive
    Brake Switch 1,Inactive
    Brake Switch 2,Inactive
    Clutch Switch,Inactive
    Vehicle Speed,0 km/h
    Vehicle Speed in Cruise Control Range,- - -
    Cruise Control Tip Switch,- - -
    Malfunction Indicator (MI),Off
    Service Vehicle Soon (SVS) Indicator,On
    Glow Time Telltale,Off 12V
    Oil Level,Normal
    Engine Oil Level Status,Okay
    Remaining Oil Life,128 %
    Engine Oil Change Warning,Active
    Regular Member benny's Avatar
    Feb 2006
    dudley
    bara is atmos presh so its 98 and the boost on that data is 89 so you have a deprestion could be a stuck waste gate ..or faulty turbo ....
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Cheers for that!, where or whats the best way forward,(testing wise) any ideas ?, many thanks.
    Regular Member cphaza's Avatar
    Hertfordshire
    kinda stumbled accross this post and thought i would pass on what i have found during several investigations on this engine at work.
    Fault has always lay with one of three things: (1)The MAP sensor being faulty or dirty (2)the egr not shutting so when the revs build up, too much exhaust gas flows back into the inlet or (3) Wastegate stuck shut/not opening enough thus creating extra pressure. Fault code is p0108. I would say most common is gunged up MAP sensor, but we are seeing more and more wastegates not functiong. they seem to be 05/06 post office vans too!!! to much stop start i guess. Never hurts to clean egr and map as a matter of course anyways. Same as the vec's realy!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by cphaza View Post
    Just noticed this thread re-apear!, just to clear this up, the fault i found in the end was a faulty boost/map sensor, a replacement cleared it no probs. cheers all.
    Mileage : 000
    So much for VX and the need for a new Turbo "eh".
  1. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  2. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
  3. CRD2 Tuning Box for V6 CDTi or 1.9 CDTi
    By The Doc in forum Parts for sale
    Last Post: 20th October 2006, 21:51
desired fuel rail pressure corsa 1.3 cdti
p0106 z13dt
1.3 cdti injection quantity
1.3 cdti common faults fuel pressure too high
corsa c 1.3 cdti map sensor location
corsa 1.3cdti fuel pressure
corsa 1.3 cdti problems
corsa 1.3 cdti overboost
vx corsa d 1.3 low boost pressure
corsa d p0106 vauxhall workshop
astra 1.3 cdti high boost pressure
barometric pressure sensor corsa 1.3 cdti
corsa d 1.3 boost sensor replacement
p0106 opel 1.3 cdti
egr pulse ratio z13dt
1.3 cdti corsa barometric sensor location
P0106 Z13DT MAP
sensore map 1.3 z13dt
corsa error code p0106
corsa d 2008 1.3 cdti problems lov presure fuel
vauxhall corsa 1.3 too much fuel pressure
corsa c coolant temperature sensor location on 1.3 cdti
p0106 corsa d
corsa c 1.3 ambient temp sensor
rail pressure low voltage input corsa c 1.3 cdti
