Thread: DPF/cat exhaust
    Regular Member MRunMotorsport's Avatar
    East Kilbride
    Default DPF/cat exhaust
    Hi guys
    Really looking for help here fast.
    Car keeps throwing up the spanner light and going on to limp mode.
    Have had it into Halley's Milngavie Glasgow and have checked the code and it was the dpf code. Cleared the code but came back on so did a regeneration on the car. This is the 3rd done on the car in 7mths due to the turbo blowing in feb. Its had both glow plugs and erg valve done as well.
    So they are now saying replace the Dpf which is also part of the cat.
    The car is a 06(facelift) 1.9cdti vectra est and and the engine code is a Z19DT engine.
    But the cost is coming in a bit steep!! like £600-800 quid steep.!!!!
    So does anyone know where you can get a cheap replacement.
    Bought the car in Dec and already spent £3000 on repairs and services.
    Car is also used as taxi and has done 110,000 miles so do not want to spend any more money on it that i have to.
    Car is getting very close to being set on fire for all the money i am spending on it.
    PRESTON
    cat and dpf are two seperate units. Replacement dpf's now avaialble on ebay at around £300.
    East Kilbride
    was told you cant get one with out the other.
    PRESTON
    im sure there is a pre cat attached to the manifold and the dpf is further down the system, might be there is a cat built into the dpf, but theses can be got on ebay . I have a 55 plate 120 19DT estate.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    def a seperate cat bolted to the turbo manifold
    and dpf are 300quid on ebay
    but i would take the dpf out smash the insides out refit and then crimp over the small pipe in the engine bay to stop the warning lights cummin on again that will do for now and cost you nothing untill you buy a new dpf or get the software removed off the ecu then you wont need one and you will get better mpg and better performance
  1. Exhaust hanger broken /rotted from exhaust.please help.
    By Dobs in forum Engine & Drivetrain
    Last Post: 25th January 2012, 21:06
  2. Duel exhaust - where to get a right hand exhaust heat shield
    By Innes in forum Bodywork & Interior
    Last Post: 29th November 2011, 00:47
  3. Fitting Dual Exhaust on single exhaust 2.2 sri
    By sdnatlst in forum Petrol Engine related
    Last Post: 1st February 2010, 10:49
  4. Where to buy oval exhaust tail pipes for signum exhaust
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 17:16
  5. Replies: 7
    Last Post: 22nd August 2007, 21:16
