Thread: 2.0 dti clutch
    Regular Member ADAM123's Avatar
    Jan 2008
    UK
    Default 2.0 dti clutch
    Hey all, my clutch has started to slip when I put my foot down. been quoted £1000. from the steelers and about £550. from mr clutch.
    I was hoping to get closer to £350 all in. is this realistic? or is mr clutch a fair price?
    its a 2003 2.0 dti vectra with 78,000 on the clock. thanks
    also is a clutch change suitable for a mobile mechanic? ta
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    No chance tbh and if your doing clutch you might as well do DMF as i would if i was you so your taking a lot more money
    Irmscher Insignia CDTI 130
    Regular Member DaveW555's Avatar
    Cannock
    The quotes you've had sound like they're changing the dual mass as well and like bigmac says it makes good sense to do it at the same time, tbh if mr clutch is going to do the dmf and clutch for 550 thats pretty bl**dy cheap but if its just to do the clutch then its expensive. whatever you do make sure genuine luk parts are fitted and its done properly ie new flywheel bolts new slave cylinder etc.
    north east
    I thought the 2.0 dti was a solid flywheel?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Nope it has a DMF
    Oct 2007
    nottingham
    just had my 2.oltr dti done clutch and dmf cost 897.00 so 550 seems a bit to cheap.mine went to a gearbox and clutch specialist they did a good job.cheap is not always best.
    tommy
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
