Thread: drl"s
    Regular Member topgun's Avatar
    bristol
    Default drl"s
    Hi Guys read somewhere on here a while ago that drl"s can be set using tech 2 equiptment..... But does anyone know the legalities if say for example the front fogs were set to come on with the ignition to act as drl lights,also has anyone on here actually done it.
    Hanging Heaton / Batley
    20 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Not sure on the tech/2 side... But I've got 501 led's wired into my fogs at min, not strictly DRL's as i didn't take a feed from an ignition live - they just come on with the side lights (but i've always had the habit of putting them on anyway)... Never been pulled or had probs, mini's have side lights in a similar location and if pulled my fog lights still work so i can show its not them...
    bristol
    Quote Originally Posted by leemarksmith View Post
    sounds a bit complicated to me mate..was it lol
    20 Post(s)
    Mileage : 110k
    I made it more complicated then it actually is, by adding switches etc...
    You could wire it up in half hour, just take a feed from an ignition live and wire in 2 side light holders. I just used normal speaker wire also
    bristol
    just been looking at what you have done mate...looks superb I soooo wish you were closer to me..
    20 Post(s)
    Mileage : 110k
    Cheers, if you just ignore all the switches and keep it basic, its just a few meters worth of speaker wire fed through to under the bonnet and your laughing
    20 Post(s)
    Mileage : 110k
    My simplified guide
    Get in behind the rear power socket and pull out these wires (hopefully you'll have the blocks)
    For DRL's take the power from the black cig lighter wire, for light switch activated take from the yellow/grey wire on the blocks... Any brown for negative will do...
    Then run the speaker wire under the centre consol, behind the glove box and out the rubber grommet in the fire wall... Then its easy to hide in the battery tray like this
    You now have power and an earth for your new bulb holders with easy access under the engine...
    bristol
    Thumbs up
    My simplified guide
    Thanks so much for your help matey
    20 Post(s)
    Mileage : 110k
    No problem
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  3. "Goodbye" blue sky "Hello" grey !
    By FIL 4822 in forum General Chat
    Last Post: 8th November 2008, 15:43
  4. "Goodbye" grey sky, "hello" blue !
    Last Post: 24th October 2008, 12:34
  5. end of year bash 2008 "" will there be one ""
    By chrisgettings in forum General Chat
    Last Post: 3rd September 2008, 10:26
