Results 1 to 10 of 27
Thread: Permanent Live in Boot?
    May 2006
    Nottingham
    Default Permanent Live in Boot?
    Hi
    Vec Sri 2005. Anyone tell me the easyist place to get a perm live from?
    A
    I'd have thought the fusebox behind the boot panel. I keep meaning to install a 12V socket in the boot of my Signum, and that's where I was expecting to ba able to tap off from.
    May 2006
    Nottingham
    ok, sounds scarey...I will get the multi meter out tomorrow....I will let you know if I find a perm live!!
    Ashington, Northumberland
    Look in the fuse box and at the top you will find a 40 amp maxifuse (big'un), The fuse terminals below and above that fuse have their live terminals towards the rear of the car. I have a feed from the top one to the cigar lighter in the rear of the car, and a feed from the lower one to a permanent live socket in the boot. Photos can be posted if you wish
    Regular Member marichrd's Avatar
    Jun 2006
    Cheshire
    Yes please Gary. I would really like to install a power point in the boot of my car - mainly for the cool box we bought the other weekend.
    Here's the plug just above the fuse box cover
    Here's the permanent live points taken from the fuse terminals
    Note the common earth for both earth wires. I drilled a hole and used a self tapper. Scratch the bodywork a bit with some emery.
    Hope this helps a bit
    Jun 2006
    Cheshire
    Certainly Does
    May 2006
    Nottingham
    Thanks...great pics!
    May 2006
    Nottingham
    I spoke to my local stealer today and they want £80 to wire an accessory socket to a perm live in the boot.....
    Does that sound expensive?
    Feb 2006
    Dorset
    Just a bit .....
  1. permanent 12v live
    By rockafella8587 in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2012, 17:53
  2. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  3. Permanent live in boot
    By montyfert in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2012, 20:11
  4. permanent live in the boot
    By Al 22 dti in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2011, 07:02
  5. permanent live
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 17th October 2008, 16:25
opel vectra c alarm system
vectra c position 1 live
vauxhall insignia boot permanent 12v power
vectra c alarm siren
where is the alarm on a vectra c
vectra c fuse for alarm
