Thread: Changing NSF bulbs
    Nov 2009
    Default Changing NSF bulbs
    I've tried a search but couldn't find the answer...
    How do you change the NSF bulbson a prefacelift? It's the dipped beam I need to change, but can't get access to it.
    That's the easy side
    Pull the screenwash filler neck UP
    This gives you access
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    You need to unclip the Washer bottle funnel. Gently twist away the clip that holds it to the slam panel, and gently twist,turn and pull it out, its only held in by a rubber washer. This then gives you the access to the rear of the headlight.
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Just lift the battery lid... I've never had to remove anything, and again thats the easy side. you could do it one handed
    Quote Originally Posted by leemarksmith View Post
    The filler tube is in the way, it's impossible to remove the cover without removing it!
    21 Post(s)
    Mileage : 110k
    Miracle
    Nov 2009
    Miracle
    I think my batterys bigger than that. It's the 3.0 V6 CDTi one, so twice the size of a normal battery.
    Cheers guys, I'll give it a go in the morning!
    Yes, there are three different battery sizes on the Vectra C
    Mine is hard up against the filler tube
    The battery also has a cover, I can't even see the battery terminals on mine
    Equally, leemarksmith appears to be left handed
    Perhaps you would like to try the offside and compare!
    I find the offside quite easy now (now that I have loosened the holding clips)
    Ironically, I can change an offside buld quicker than a neaside now
    21 Post(s)
    Mileage : 110k
    Never had a problem with either to be honest, but cant 1 hand the nearside
    Must be my small girl like hands
  1. Replies: 13
    Last Post: 23rd March 2013, 23:10
  2. changing headlight bulbs
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2011, 22:27
  3. changing bulbs on front
    By astratovectra in forum Bodywork & Interior
    Last Post: 9th March 2008, 21:07
  4. Changing bulbs.....
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2008, 14:30
  5. WARNING to all changing bulbs
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2008, 12:03
