Results 1 to 10 of 24
Thread: Snapped tensioner bolt, help :(
    Oct 2009
    South Yorkshire
    Trim : Sri
    Engine : Cdti
    Mileage : 130k
    Default Snapped tensioner bolt, help :(
    My mum has a 53 2.2 DTI vectra and i investigated the problems it has and found the lower AUX tensioner bolt was loose i thought i could just screw it back in but no it had sheered off :/
    any help ?
    Cant drill it without dropping engine as chassis legs in way.
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    i think its part the bracket which holds aircon pump in place take it of and drill it out alot of messing but needs doing.
    Oct 2009
    South Yorkshire
    Trim : Sri
    Engine : Cdti
    Mileage : 130k
    Ill go and have a look now.
    Regular Member DaveW555's Avatar
    Cannock
    the only other option is to put a shorter bolt in and thread lock it
    Oct 2009
    South Yorkshire
    Trim : Sri
    Engine : Cdti
    Mileage : 130k
    no chance of that mate there is no thread for it to screw in the old one is in the way
    Norwich
    Trim : SXi
    Engine : 2.2
    Even if you could drill it out it would be a pig of a job to do without damaging the thread.
    Try soaking it with WD40 and then putting two nuts on it and tightening them up against eachother and see if you can move it and try to take it out.
    Other then that its getting some heat on it so you can loosen it and get it out so you can put a new one back in
    Cannock
    its snapped off in the hole on the 2nd pic, the first pic is what has come out, if you cant put a shorter bolt in then you'll have to drop the air con pump and bracket, drill it and helicoil it back to the original thread.
    Oct 2009
    South Yorkshire
    Trim : Sri
    Engine : Cdti
    Mileage : 130k
    Hopefully if i can get the bracket off i can drill it and get a set of stud extractors on it.
    Going to get it in my garage up on some ramps tomorrow and hope i can get the bracket off.
    leicester
    Trim : Sri xp2
    Mileage : 100000
    the bracket will come of quite easy then just drill it mate or try and get a secound hand bracket.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Try and drill a pilot hole with a right angle drill then try an easy out?
  1. Aux belt tensioner bolt...
    By cont1204 in forum Engine & Drivetrain
    Last Post: 26th April 2011, 08:55
  2. bolt snapped
    By tappetpaul in forum Engine & Drivetrain
    Last Post: 14th March 2011, 23:43
  3. Snapped Bolt
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2009, 14:06
vauxhall belt tensioner block snapped
tensioner bolt worked loose vauxhall
