Likes Likes:  1
Results 1 to 10 of 18
Thread: Vectra wont start when warm!
    troon
    Default Vectra wont start when warm!
    My vectra 03 1.8 ls starts first time from cold, but when i drive it short/long distance and stop i go to start but it wont! the car seems to either not be getting fuel or a spark. i have checked battery voltage and it is 12.7 which is what it is suppose to be. the engine management light is not comming on so on fault reading. anyone else had this problem i dont want to take to vx dealer yet as i am tighter than two coats of paint!
    Full Member Big Sig's Avatar
    Does the temperature gauge work ok?
    troon
    Question
    Its work one day and not the next.
    It could be related. If the car is hot but the ECU thinks its cold then it may overfuel and "flood" the engine so it will not start.
    Could be the temperature sender in the thermostat housing imo.
    You need to see when it fails to start if the gauge is working or not. Mind you I am not sure if it has more than one temp probe for the engine temperature.
  5. Likes Grumpy1954 liked this post
  6. #5
    troon
    thanks i will check the thermo, there is no smell of fuel from the engine bay, so dont think its flooding.
  7. #6
    I take it you have checked the plugs already etc?
  8. #7
    troon
    no i have'nt checked the plugs as i found it strange if it was the plugs it would satrt at all, i aslo thought it might have been a the coil pack but again if it was it would'nt start at all. thought i would put on a post to see if anybody had the same prob to save me time.
  9. #8
    Not true. Sometimes components break down when hot but are ok when cold. IRS worth looking at them when it's free.
  10. #9
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Might be worth while changing the spark plugs, maybe something simple like a cracked spark plug.
  11. #10
    Regular Member DaveW555's Avatar
    Cannock
    Crank Sensor will also give this problem take your pick which you do first.
  1. Vectra c 2.2 dti wont start
    By latif in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 07:06
  2. Vectra 2.0 DTi difficult to start when warm
    By C470 in forum Engine & Drivetrain
    Last Post: 11th July 2012, 16:35
  3. vectra c 2 dti wont start
    By ricky192 in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2009, 23:50
  4. vectra wont start
    By damien whiley in forum Engine & Drivetrain
    Last Post: 6th May 2009, 17:30
  5. my vectra wont start help please
    By raymond1711 in forum Engine & Drivetrain
    Last Post: 14th April 2008, 13:04
my vectra has trouble starting when warm
vectra 2.2 petrol wont start when warm
vauxhall vectra wont start when hot
Signum wont start when hot
vectra hard to start when hot
veftra had starting when the weather is warm
2010 insignia wont start when hot
vauxhall zafira wont start when warm
vectra c wont start when warm
my 2012 vauxhall corsa wont start when hot
vectra C wont start when hot yet starts when cold
vectra dti wont start when warm
vectra c 1.8 wont start when warm
vauxhall vectra vxr wont start when engine is warm
vectra not starting when warm
vectra 2.2 dti clicking not starting when warm
vectra when warm wont start
vectra c not starting when warm
