Thread: Lowering with 19s >???
    S.Shields (Newcastle)
    Default Lowering with 19s >???
    Hi, Am thinking about a drop of 30mil but got snowflakes on....
    Will they catch or rub, is it adviseable??
    Help plz! ?
    Any1 ??? at all ????
    Full Member Big Sig's Avatar
    You have the sri so a drop of 30mm may only be a further 15mm as the sri's are already 15mm lover than most models.
    I can't see a problem tbh.
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    i,m on 19" snowies .............ive dropped 45mm front 40 rear ....no problems at all
    http://www.vectra-c.com/forum/showth...ulmans+lowered
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Quote Originally Posted by soulman View Post
    Same as above, you could even get away with another 20mm before it catches IMO.
    i dont wanna go for the chav look want to tighten everything up a little so maybe ill drop it 40 then.......
    18 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    Quote Originally Posted by neil3734 View Post
    you need to drop the front more than the rear so as they look the same in the wheel arches .front wheel arch is higher if you look .
    21 Post(s)
    Mileage : 110k
    Approximately 10mm when i measured mine as standard
    Jul 2010
    Londonderry Northern Ireland
    lowered my girlfriends supposidly 60mm the other day, sitting brilliant over the 19" snowflakes and no rubbing at all
  1. Lowering on the sri.
    By Roy_Vec in forum Tuning
    Last Post: 13th September 2009, 09:15
  2. Lowering again
    By Ziggy in forum Handling & Braking
    Last Post: 2nd June 2009, 14:19
  3. Lowering
    By euro-dee in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2009, 01:22
  4. Lowering
    By s1nglef1sh in forum Handling & Braking
    Last Post: 6th November 2008, 22:46
  5. lowering???
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2008, 23:49
https:www.vectra-c.comforumshowthread.php115331-Lowering-with-19s-gt
