Results 1 to 10 of 18
Thread: Another CDTi "missing" question
    Jun 2007
    Scotland
    Default Another CDTi "missing" question
    Hi,
    Have the 120 8V CDTI on my vectra which has just started to mis-behave in that there is an occasional judder between about 1600 and 2200 RPM. I have done a good bit on searching here and have concluded it can't be the no3 injector problem as that seems only related to the 150. There is also no DPF (that I'm aware of) or swirl valve. So this leaves me:
    - EGR
    - Throttle body
    - Boost sensor.
    It had a new turbo fitted at start of the year after failing at 34K miles (06) so don't think it's anything related to that and when I accelerate hard it's fine, pleanty of power.
    Any thoughts? I haven't seen a how 2 on EGR for the 120 or on the throttle body. Can anyone help with this?
    I chucked in some powerenhancer cleaner last night to see if that would help!
    Thanks,
    Ali.
    Regular Member yadziyad's Avatar
    London
    might be the crank shaft sensor as i had the same issue
    Jun 2007
    Scotland
    There's no error codes logged and MIL light is out - did crankshaft sensor fault show up (ie how did they diagnose it).
    Thanks.
    London
    the spanner warning light came up and the checked with computer, so maybe yours is ok if its not showing up
    Glasgow
    I had the egr valve replaced and have ran with Forte cleaner in the tank and still have the problem Srrms to be a freebie problem if you buy Vauxhall these days. My spanner light did come on but would the crankshaft sensor not record a code error ?
    S.Shields (Newcastle)
    Am glad i have the petrol!!
    Jun 2007
    Scotland
    Quote Originally Posted by morhan View Post
    I believe any sensor faults are logged until erased (or so I thought) however I had my EHPS pump not start one time I got into the car and I think the spanner showed for that but after switch off / on the spanner was gone and no DTC's logged (i have an ELM tool so can check for them)
    Anyway, I've not seen any faults on mine with this latest "fault". I'll maybe try and clean the EGR and see if that helps.
    Glasgow
    there is also the rubber hoses which link to the turbo which some time perish - The is a good topic on i think this forum about the hoses
    Jun 2007
    Scotland
    Yeah I don't think it's that as car accelerates fine (I only see this issue when crusing at steady speed and making small throttle adjustments if that makes sense). My experience of turbo hoses going is that when they split there is pretty much no turbo boost - I could be wrong!
    May 2006
    Canterbury
    thats the sort of problem i am having on my 150 i am thinking that it may be the egr even though i did a thorough recon on it!
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. White smoke and "missing"?
    By johnaw in forum Engine & Drivetrain
    Last Post: 5th January 2012, 16:04
  3. Question about "daytime running lights"
    By NIGHTCD in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2010, 16:45
  4. Silly "newbie" question time
    By smoggydovit in forum Engine & Drivetrain
    Last Post: 28th June 2009, 21:55
