Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 44
Thread: Aftermarket Parking Sensors
  1. #11
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Piece of cake Martin. I followed the measuring instructions HERE.
    Measure twice, cut once as the old saying goes. I removed the boot carpet and then removed the black plastic area beside the boot catch. I used the grommet that takes the cable for the rear number plate lights through the back panel as my route for the cables. I just cut a large cross in the grommet, obviously watching that I didn't damage any cables. Hardest part is adding the locking ring to the rear of the sensors because by leaving the bumper on your working blind, however once you get it on small stubby screwdriver helps aid them home. Mounted the control box inside the rear wing beside the fuse box. and ran the beeper inside the boot lining and out through one of the 3 holes near the parcel shelf hinge.
    Job done in 1 hour 10 minutes, and the Silver is a very good match on my car too, very pleased.
  2. #12
    Regular Member vectra_'s Avatar
    australia
    where do you put the headset ?? that box type of thing :s dont no what you call it
  3. #13
    Shropshire
    Wink
    Left hand cubby hole, where the horns mounted. FWIW, I did mine last monday, and was very proud of myself (only ever changed a bulb before!!), using the How2 from here. Took about 2 and a half hours. Mine were £16 from Ebay, and the silver is a good match on a Star Silver Vectra - as good a match as the bumper to the rest of the car
  4. #14
    australia
    so can hide that thing?
  5. #15
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by vectra_ View Post
    The control box
    Yes. Mine is, as Fishmichael says, in the left hand cubbyhole, beside the rear fuse box, where the first-aid box goes.
  6. #16
    australia
    where can i get it fitted ? :s
  7. #17
    Blantyre
    If you want to nip over to mine i can help ya
    On a serious note mate, DIY , very easy to do
  8. #18
    aberdeenshire
    Just ordered my set today
    Does anyone know which models are affected by the bulb warning light?
    1 have a 05 facelift SRI
    Russ
  9. #19
    Shropshire
    Mines a facelift, only got the bulb warning with the ignition on and lights unplugged, so I know it works. Had no problems/warnings or anything at all with mine. You're only taking a feed from the reverse light cable, so not actually interfering with any bulbs.
  10. #20
    luton
    i've ordered some, and they are black, however my vectra is metro blue, i'm just wondering if i can i hide them in the black bit below the bumper, has anyone else done this?
  1. fitting aftermarket rear parking sensors , best way to get into boot?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2012, 11:08
  2. fitting aftermarket rear parking sensors
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2011, 19:45
  3. OEM Parking Sensors with aftermarket module
    By djr69uk in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2011, 19:32
  4. Vauxhall Aftermarket Parking Sensors
    By Craig Rogers in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2008, 14:18
  5. aftermarket parking sensors
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 10th April 2008, 20:20
