Thread: Heavy steering intermitent
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    Default Heavy steering intermitent
    Hi all yes its that time again i have a problem,
    at lows speedsif my wheels are in full lock it sounds like my tyres are scrubbing and when I turn quickly the steering goes really heavy, also I can hear a knocking coming from the front even on idle (not engine knocking ) Ive took it to the garages too many times to care but no one can ever give an answer.
    I have lost all faith in driving it and currently walking everywhere as it really does scare me.
    Im more curious than anything as this is the final straw for the vectra im looking for a new car (v70 t5 7 seater) but do i repair and sell the vec or just scrap it, shame for a 54 plate elite to get scrapped though.
    Thanks all
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by craigbarlow18 View Post
    Seen this a couple of time with various cars, all instances it was simply low power steering fluid level, might be worth a check, often overlooked.
    will check that, I would assume they should have, is it shared resovoir or go its own?
    UPDATE; Well how peed off am I with the garrage that fitted new steering rack.... had a look round car today, i think its the sub frame both front bolt was loose i mean not even finger tight. tightend them up and knocking noise has ceased still got the heavy steering if i violently turn steering wheel so going by the failure to tighten these bolt id hazzard a guess that the power steering fluid was never topped up. im in half a mind to go back and play up **** with them but what do I gain as i dont trust them near my car at all.
    My question is what other bolts should be checked on the basis of a rack replacment??
    Finally who at vauxhall designed the power steering resovior and placed it out of sight. CLOWNS!!!!
    Thing is ive never had a warning light come on regarding low fluid and ive not checked the level yet as i cant be bothered/ dont have time tonight to remove all the crap that needs to be removed just to check the level.
    thanks all.
    How much do matches cost now days
    Jul 2010
    Glagsow
    \HI, I have had the same problem, replaced the steering rack a month ago and the steering is very heavy, power steering bottle (for what I can see) has plenty in it but that could be an oversight on my part.
    Any other suggestions of another possible issue I am overseeing?
    Thanks in advance
    Regular Member Exclusive BV's Avatar
    West Midlands
    Have you tested the alternator under load?
    If the power steering is not being fed properly, it can give problems
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    My brother had this and it turned out to be a faulty rack i know you have had it changed but it might be faulty
    Irmscher Insignia CDTI 130
    Jul 2010
    Glagsow
    thanks guys
    I will try and get it tested and hopefully only a small issue
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    Yes exactly... Mine was low on steering fluid and did like that exactly..
    Just topped the fluid up and it was gone..
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Hi just reading about your problem the vectra c as electro/hydraulic power steering system, the unit is mounted behind the front bumper o/s on preface lift vectra c like yours. You could check electrical connections at this unit as they do become wet, dirty, and even corroded, also behind the steering wheel is the CIM integrated in the CIM is the steering angle sensor. This sensor communicates with the unit behind the front bumper switching on and off when the steering wheel is operated left and right worth checking reprogramming/calibrating if required......
  1. very heavy steering
    By GCusdin in forum Suspension, Wheels & Brakes
    Last Post: 4th December 2012, 19:10
  2. heavy power steering
    By datiger79 in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2011, 18:57
  3. Slightly heavy steering
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2009, 09:55
  4. Steering is a little heavy and juddery
    By freshprince in forum Suspension, Wheels & Brakes
    Last Post: 21st August 2008, 11:57
  5. Steering heavy HELP !
    By cpt slow in forum Suspension, Wheels & Brakes
    Last Post: 22nd February 2006, 09:03
vectra c steering going heavy
vauxhall vectra heavy steering and knocking noise
vectra c heavy steering
front skirt steering heavier
signum steering getting heavier
vectra steering goes heavy when warm
vauxhall signum heavy steering
2008 vectra sri diesel power steering not centering
vectra weighted steering
vectra instrumenmts and steering heavy
steering heavy and knocking
steering pump vauxhall vectra heavy
vectra c 2.2 direct stiff steering
