Thread: a little bit of help please
    leeds
    Default a little bit of help please
    hi all just wondered if any one has had there o ring blow on one of there fuel filter housing on a cdti where the fuel lines go in as mine went today and was squirting diesel all over ive managed to get a temp o ring and its workin at the moment but wondered will it need to go into the stealers to get sorted out properly
    preston
    rolleyes
    do you mean the o ring between the lid and body of the filter housing
    or the small white rings where the fuel lines enter the housing
    If it the latter, then the blue tabs are held in place by black retainers that are part of the housing
    my white rings are free adn dont play any part
    sounds like someone hasn't put your lines back properly or
    worse still the retaining parts are missing therefore allowing the pipes to leak.
    if this is the case then under real pressure they will come off and leak fuel everywhere. try cable ties as a short term fix. but if it is broken then its a new fuel filter housing..
    sorry but Vx will supply at great cost
    leeds
    yeah its the latter.there was diesel everywhere but like i said put some more o rings in and its holding off at the mo.wont vx just sell the black clips and o rings that retain the blue pipe in.otherwise how much am i looking for a new one
    preston
    i'll take a photo tomorrow and upload what it looks like on mine now
    i guess from what you're saying that the black tabs that hold the blue retainers in place might be broken
    this would allow the pipes to work loose under pressure.
    in the meantime use cable ties to secure the lines in place, drive like your granny is with you and then get a new housing
    mine was damaged by garage , denied it of course
    they,re about £100 from Vx but you get filter in it and that comes in at about 18£ normally
    leeds
    thanks for the info.the black clip looks intact tho unless i cant tell if there is a lug or anything missing.
    preston
    take a pic and upload what yours looks like, maybe the lugs are missing on back where its harder to see
    i'll have a peep at it once you've done
    the new housing came with
    housing
    filter
    o ring for housing
    2 tiny white o ring and 2 blue retaining clips which fit over the fuel lines and help retain them
    as the fuel pressure increases , the blue retaining clips push back against the black lugs holding it all in situ
    it only takes one broken lug to lead to failure
    the other thing i'd check is that the fuel filter housing lid is secured properly......its a pig to tighten / untighten without good tools
    we put a post on this a few days ago about how to change fuel filter
    cheers
    Middlesex
    Default cdti fuel filter
    Check the bowl for cracks where it fits in at the back.
    had to change 1 a couple pf weeks ago , had cracked where the lugs hold it in the crash cage.
    Not listed as trade club item but still got it for less than a 100.
