Thread: fiat doblo head gasket??
    Regular Member nigec's Avatar
    barnsley
    Default fiat doblo head gasket??
    Ive suspected my head gaskets gone as my water coolant as disappeared and i presume it went into the oil. So i dropped all oil, then refilled water to examine how bad leak is. So i left sump plug out and filled with water, then water started trickling back out through sump hole. Does this sound like head and would any of the K seal be any good for a temp repair ??
    Regular Member vauxhall-john's Avatar
    fife, scotland
    defo sounds like H/G i wouldnt temp repair it mate you'll probably find the head is slightly warped aswell if there is water coming out through the sump that fast..!
    Norwich
    Trim : SXi
    Engine : 2.2
    That does sound pretty bad never had it happen that quick! Try the K seal if it works great if not you wasted a tenner
    barnsley
    time to get rid then i think.
    Regular Member petel's Avatar
    Nov 2007
    bristol
    could be liner seals...even worse than head gasket
  1. fiat egr gasket,what difference does it make?
    By mike. in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2013, 19:48
  2. Fiat EGR Gasket Question....
    By Dan_BlackSRi in forum Engine & Drivetrain
    Last Post: 9th August 2012, 16:25
  3. Fiat EGR Gasket for a 150 CDTI
    Last Post: 6th June 2012, 10:04
  4. Fiat EGR Gasket
    By bafoo in forum Engine & Drivetrain
    Last Post: 20th January 2011, 16:51
  5. Fitted Fiat EGR gasket.
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2009, 19:58
