Results 1 to 10 of 19
Thread: It sounds like I'm running on a flat!!!
    Staffs
    Default It sounds like I'm running on a flat!!!
    My vectra is occasionally making a noise from the front after cornering or heavy acceleration. The noise sounds like one of the front tyres is flat?!? Its clearly not got flat tyres!!!!!!!
    It does not happen all the time but it is becoming more common? Could it be the wheel bearing?
    Regular Member Exclusive BV's Avatar
    West Midlands
    sounds like it could be a bearing but normally they are noisy all the time or when steering a certain way.
    What sort of noise is it?
    Staffs
    it sounds like a flat tyre at low speed, its like a soft thud.....thud....thud....thud!!!!?
    Quote Originally Posted by Exclusive BV View Post
    Worn bearings on the Vectra C don't make any noise, makes them difficult to diagnose unless you have the car on a ramp
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    have you got a flat spot on your alloy rim... best to get it checked out
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    preston
    presume you've nothing stuck in your tyres ?
    is braking system ok?
    Staffs
    braking fine, alloys fine & no nuts, bolts or stones in the tyre! ? ?
    A long time ago I drove over something that gave an occasional banging sound from the nearside front tyre
    Initially I couldn't see what it was, so drove forward such that I could inspect each third
    I found a large split elastic band wedged in one of the treads!
    If you suspect the tyres, then post a little more info, including make, type, profile, mileage / age per axle
    preston
    sorry if this is real obvious,
    are all wheel nuts tight? and torqued to correct rating ( 110nm i think )
    just wondered
    also are wheels catching anything - cables etc anything loose under wheelarch ?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Don't they, do they turn red when they need changed then
    Quote Originally Posted by Caveman_nige View Post
    Thats a fair point to make and anther thing i'd be looking at are the driveshafts
  1. Replies: 3
    Last Post: 7th June 2012, 15:42
  2. Running flat
    Last Post: 30th April 2012, 22:17
  3. Pug 307 HDI - New battery but sounds flat
    By damers2000 in forum The 'Off Topic' room
    Last Post: 7th January 2011, 21:51
  4. 2.0 dti EML light,sounds like it is running on 2 pots
    By davesharp in forum Engine & Drivetrain
    Last Post: 7th December 2009, 20:57
  5. Flat battery and cicking sounds from fuseboxin boot
    By Stevo K in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2009, 15:18
