Thread: New Clarion Head unit Fitted (Pics)
    Regular Member platty's Avatar
    Jan 2008
    Paisley
    Default New Clarion Head unit Fitted (Pics)
    Well after a bit of head scratching, I've got my new head unit fully fitted and working so thought I'd share some pics.
    Ok so to fit this I ordered the connects2 double din facia adapter which is a reasonable match in colour but not perfect.
    On my first attempt to do this install I ordered an autoleads steering wheel interface (pc99-x80) with clarion patch lead. This is where I encountered my first problem, the steering wheel controls worked fine but I didnt realise that the clarion's Navigatior wouldn't operate using only the gps signal but required a speed pulse and reversing signal Input. Unfortunatley The autoleads interface did not provide these.
    I tried to tap the speed pulse wire from the quadlock connector but I still didn't have any success. At this point I decided to change the autoleads interface for the connects2 one (ctsvx002). Not only does this give a speed pule, reversing signal and illumination output but also allows you to change the time on the vauxhall screen using the steering wheel controls, saving the need to replace the oem unit.
    Once I had swapped the interfaces over and connected up the speed pulse etc I finally had working nav . all that was left to do was run the Ipod cable, which is in the glovebox for now. Route the microphone for handsfree and voice control, I decided on the A Pillar. Find a suitable place to fit the bluetooth adapter There was enough space under the ashtray, and route the gps antenna to the centre speaker apeture.
    Now That it's fitted, so far I'm really impressed the sound quality is very good, the picture quality is also impressive. the menus are intuative and fast to respond as is the touchsreen. The navigation is very clear and the addition of the harddrive means I no longer need to carry around so many cd's. all in all I'm very impressed.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Looks a very good head unit indeed, lots of features
    Jan 2008
    Paisley
    Thanks mate, I took a bit of a risk as I bought it at a liquidation auction so if it had been faulty i'd have been out of pocket. As everything is working now its turned out to be a bargain, I paid 340 for it, and it still retails @ 1000 and that's without the bluetooth adapter. :-D
    Lancashire
    Trim : XP1
    Mileage : 66000
    It looks it, I have looked at some of the cheap Clarion double dins, but nothing like what you have fitted.
    Oct 2007
    Shropshire
    Looks great, I wish I could afford one! Just a thought, is that mike in the way of the airbag?
    Jan 2008
    Paisley
    Quote Originally Posted by mucklestone View Post
    As far as I'm aware it shouldn't obstruct the airbags, I'm pretty sure where I've attatched the mike is just a plastic clip that holds the A-Pillar trim in place. If anyone knows different then I'll definatley find a new location for it.
    Nov 2010
    Maidstone
    To be fair, if you have a big enough accident to fire off that pillar airbag the mic will be the least of your worries
    Engine : 1.9 CDTi
    Dont think all Vectra's have airbags there.
    If they do it normally says 'airbag' on the clip
  1. sony xav601bt double din head unit fitted - pics
    By tracer in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2013, 19:26
  2. Fitted my head unit
    By andrew_lumb in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2012, 00:18
  3. Head Unit Fitted
    By JamieD27 in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2011, 07:45
  4. New Head Unit Fitted
    By Heronman in forum ICE Gallery
    Last Post: 24th May 2010, 10:06
  5. new head unit fitted
    By jamie226 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2009, 20:20
