Thread: Slight rattle on gear change?
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Default Slight rattle on gear change?
    I was driving down the motorway today giving it some beans. When I changed gear on about 4500 revs into 5th then put my foot down I get a slight rattle type noise for about one second, then it goes away.
    This only happens when I hoof it....push really hard. Otherwise everything is running great. is this an early sign of something on its way out??
    Any idea what this could be gents??
    Cheers.
    Regular Member pugs,signum's Avatar
    swansea
    possibly Concentric Slave Cylinder (thrust bearing)
    is on its way out and is rattling against the springs of the clutch plate?
    Trim : Sport
    Engine : Petrol
    Hmmm I don't like the sound of that.It sounds expensive.
    swansea
    gearbox out job im affraid! just had my signum 1.9cdti done with a new dmf, clutch and thrust bearing! thought the dmf was shot as it rattled and saw the parts after and the thrust bearing had gone and was rattling on the clutch springs but was happy with getting it all done anyways!
    Trim : Sport
    Engine : Petrol
    It doesn't happen under normal driving only when I really go hard. I've only noticed it two or three times in the last year and never really thought much of it. so what do I do? can I just leave it until it increases or get it sorted straight away. Will it damage anything else if its just left alone.
    Thanks for your help.
    swansea
    personally i would leave it and wait till it makes the noise more often!
    would suggest you check your gearbox oil is full, if you got a haynes manual they will tell you how to check it and fill it!
    the first time mine rattled i was near some road works and it sounded bit like a pneumatic chisel digging until i noticed there were no workers about because it was a sunday . that was the worst it ever sounded, it was noticedable when giving the car a rev and when the revs dropped back to 1000rpm it was rattle slightly.
    Trim : Sport
    Engine : Petrol
    Yeah that's what I'll do. If it ain't broken don't fix it.... At least I'm on the case, thanks.
    At the mo its only a slight noise under heavy load in really high revs. and I don't drive like that as a rule. I think I'll leave well alone until it becomes noticeable in every day driving.
    2003 DTI siggy. so far.....
    Air box mod
    Pipercross filter
    Drilled n grooved Discs n pad upgrade
    bullet ariel
    Opel badged
    Painted and decal-ed calipers
    egr + boost sensor cleaned..
  1. Slight clunk when you engage a gear
    Last Post: 17th April 2012, 08:23
  2. slight rattle on first start up.
    By patch22 in forum Engine & Drivetrain
    Last Post: 17th June 2011, 21:03
  3. slight change
    By shb1988 in forum Quick Photo Album
    Last Post: 15th April 2011, 18:34
  4. Slight rattle noise...
    By Stevie-B in forum Engine & Drivetrain
    Last Post: 4th July 2008, 13:22
  5. Slight rattle front end...
    Last Post: 10th March 2008, 13:36
