Hello guys.
Just recently got my vectra back after having the full belt kit done along with dmf and clutch. Its the 1.9 CDTI 120. The problem is since having the work done i've noticed when i use the gears to help slow the car down as i let the clutch up i hear a bang and also it does the same when i reverse up hill. Could something just needs tightening up properly or is it more likely the drive shaft on the way out ?
The car drives perfect otherwise, pulls fine when i put the toe down.
Oh one other point to mention is the mechanic told me the crankshaft pulley needs doing too..
