Thread: limp home mode
    Jul 2010
    east midlands
    Default limp home mode
    hi all
    my car seems to be stuck in limp home mode
    it drives like a bag of spanners has no accelaration any ideas
    preston
    Wink
    what year / engine type.
    if you have code reader , try getting the code and come back to the forum.
    No code reader then there's a how too in the how too section which allows you to pull the codes off although its not as simple as code reader.
    after that
    have you tried turning it off and restarting? or taking battery off for 30 mins to see if it clears itself?
    the most obvious and i guess most likely thing after this that you can do without costing anything would be to clean EGR and Boost sensor. How toos for that aswell.
    check vacuum hoses and intercooler hoses. plenty of links about these
    again all can be done for free......
    try these then come back for more help.
    someone on here will solve it for you I'm sure
    good luck
    Jul 2010
    east midlands
    sorry it's a 2005 2.0dti
    don't have a code reader it did come up with a fault on the display and when i checked the handbook it said water in the fuel filter .
    i've had the filter changed but made no difference
    EVERYWHERE
    Quote Originally Posted by trickster75 View Post
    Try posting your problem in the 'Engine & Drivetrain' section. You'll get more 'hits' there.
    Jul 2010
    east midlands
    cheers diesel i'll try it
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Please keep the one thread active and not post in different sections about the same problem in future
    Irmscher Insignia CDTI 130
    preston
    when you drained the fuel filter did you see water?
    if you let it settle there would be 2 discrete layers mostly fuel but a smaller layer of water
    unless you have water ingress into your fuel system, i suspect this isn't your problem especially if you put a new filter in and drained it at the time
  1. limp home mode
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 22nd September 2012, 09:12
  2. Limp Home mode
    By Bredsticz in forum Engine & Drivetrain
    Last Post: 12th July 2012, 19:43
  3. limp home mode
    By fig in forum Engine & Drivetrain
    Last Post: 20th January 2010, 23:18
  4. CR2 going into limp home mode
    By plasma in forum Diesel Engine related
    Last Post: 17th April 2006, 20:45
