Thread: heated rear window not working
    Regular Member dodus's Avatar
    Jun 2009
    edinburgh
    Default heated rear window not working
    Hi guys
    the problem i have is that my rear window has stoped heating up,i have checked the fuse which is fine anyone got any ideas on how to fix this,maybe its a loose conection????
    Jun 2009
    edinburgh
    just took off all trim and chechecked conections all seems fine but it still wont work
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    it maybe that youve broken the heater eliment.......can be done if youve over loaded the boot with the parcel shelf out
    Jun 2009
    edinburgh
    Quote Originally Posted by soulman View Post
    where is the element and any idea on how to fix this ??
    ayrshire
    woke up this morning and frosty in good old scotland , went in car switched on rear heated window and nothing , came in checked fuse location and from what i can see it is 40amp in boot number 4 down, can anyone confirm this, my problem is their is no fuse in that location in my car , i havent had it very long but i was sure it worked previously ..anyway if anyone can confirm fuse location ...thanks...
    stockport
    Arrow
    Quote Originally Posted by morri76 View Post
    This is correct,however,I swapped my 40amp fuses over and wasn't sure which one I had taken that one out of.I checked the handbook and put it in the one that it specified and it still wouldn't work so I put it in the one above,(heated seats,I think),and it worked fine.Check it out,you have nothing to lose.FELIXX.
    ayrshire
    thanks for the reply mate , i will give it a go tomorrow and post reply , thanks again...
    ayrshire
    hi folks , it was the fuse, my car was recntly repaired after someone drove into me and they had to remove my tailgate so i assume they must have taken fuse out and not put it back, well its either that or im mental and didnt see it working previously lol....thanks again
  1. Rear Heated Windscreen Not Working?
    By paz_badboy4life in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2011, 13:48
  2. heated window problem dont seem to be working
    By pugs,signum in forum Vectra C / Signum Troubleshooting
    Last Post: 29th November 2010, 20:10
  3. Heated Rear Window
    By si_hoss in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2009, 15:03
  4. Rear heated window
    By BigP in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2006, 20:15
vauxhall vectra heated rear window not working
vectra c rear window heater not working
vectra c heated rear window not working
vectra C rear window demister not working
vauxhall meriva rear heated window not working
vauxhall vectra c rear window heater not working
vectra rear window heater not working
vectra c rear demister not workingcorsa d heated rear window not working2006 vectra c demista button not lighting uprear window demister not working vauxhall vectra vauxhall astra heated rear window not workingcorsa c rear window heater not workingvauxhall vectra rear window heater not workingvauxhall insignia rear windows not workingvectra c rear window heater fusevauxhall vectra rear window heaterheated screen fuse on vectra c vectra 06 fuse for rear window demisterwhere is the fuse for back window demister vectra cvauxhall Vectra c rear heated windowcorsa c rear defog not workingback windows on my vectra not demistingheated back window not working on vauxhall vectra 06 heated back window not worling vauxhall vectra 06
