Thread: knocking when putting power down
    Regular Member Graeme01's Avatar
    Aug 2009
    wirral
    Default knocking when putting power down
    been getting progressivley worse now! when i put my foot down abruptly there is a distinct knocking coming from some part of the dive train as if something is loose. To me it feels like a gearbox mount or something similar. i will have a look when it stops raining
    just wondering if anyone else has had problems with the gearbox mounts?
    preston
    have you had any major work done on the car recently??
    are wheel nuts all tight?
    i'd take wheels off and give a visual to all the parts you can see. Check for wear. I'm sure someones posted on here about how to check for wear / tear on running gear both front and rear.
    that should exclude some of the more obvious issues
    Regular Member DaveW555's Avatar
    Cannock
    stands a chance with the front/back mountings theyre an absolutely shocking design and I've changed quite a few now (including my own), should be easy enough to spot if they've gone.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    As dave said the norm culprit is th gearbox mount that wears and when you floor it the loose mount takes up the back lash hence the clunk but def needs replacing as it outs strain on the rest of the drivetrain
    Aug 2009
    wirral
    right just been under the car and it is definatley the gearbox mounts! they are as slack as a badger
    anyone know the cheapest place to get the two new ones from?
    cheers
    north east
    also anyone got a how to and part numbers for these ?
    Aug 2009
    wirral
    anyone know of a cheap place to buy these?
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
  1. knocking on power steering
    By keatsy in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2011, 17:57
  2. power steering knocking
    By keatsy in forum Troubleshooting
    Last Post: 24th January 2011, 16:06
  3. 2.2DTI losing power and knocking noise
    By Celes in forum Engine & Drivetrain
    Last Post: 5th April 2010, 03:25
  4. Putting in new seats
    By george88 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2009, 19:30
  5. Putting Windows Down With Key?
    By joejdx in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2009, 00:13
