Thread: Fitting vxr rear diffuser to sri xp
    Regular Member 2.2 oil burner's Avatar
    Oct 2007
    wales
    Vehicle : Sri
    Trim : Xp
    Engine : 1.9 cdti 150
    Question Fitting vxr rear diffuser to sri xp
    Hi all, just bought a sri 150cdti with x pack . I want to fit the vxr rear diffuser but i'm wondering how it fits, will it go straight on o.k or has it got to be fitted between the vxr lower spoiler and the bumper . I've done much searching on the forum but cannot find the answer. Thanks in advance...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Unfortunatly the skirt has to come off first
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    It is possible to change this without removing the xp skirt. It fitted a BTCC rear difuser on my xp2 without removing skirt as that looked like a mare of a job on its own.
    I removed my bumper and used wire cutters and a stanly knife to remove the original rear difuser by cutting it in the weakest ppint near the exhaust. This allowed it the be pulled out. You have to pull carefully as its a snug fit but I got mine out in 2 pieces.
    Worth a try as you have nothing to lose and everything to gain.
    Regular Member leonvectrac's Avatar
    south shields
    its hard but possible, i done it with mine.
    Oct 2007
    wales
    Vehicle : Sri
    Trim : Xp
    Thanks for replies. Yeh i thought it might have to come off first and worried it might be bonded on. How exactly is the lower skirt attached to the bumper?
    south shields
    bonded on, which is why i thought i would try get diffuser on without pulling skirt off and ruining it in the process am glad i did as it was fidily but possible i was just carefull so that i did break the diffuser.
  1. removing and fitting rear diffuser
    By MURDO in forum Styling
    Last Post: 17th August 2012, 23:06
  2. Fitting VXR Diffuser
    By coddy2200 in forum Styling
    Last Post: 18th May 2010, 16:57
  3. Rear Diffuser
    By SeanS in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2009, 16:59
