Thread: 2.2dti help
    birmingham
    Default 2.2dti help
    hi all
    got a sri dti yester from auction as a non-runner due to starter not turning, got it going from push starting very easily.
    but now the spanner light is always on and it wont go above 3000rpm so i pressume its in limp mode but are there any common problems that cause these. it will be tech2'd on tuesday hopefully but wantedto know if anyone had any ideas
    thanks
    birmingham
    got the starter sorted, needed a new solonoid.
    found a large split in a intercooler pipe to turbo and sorted out slight lag, changed MAF for 100% working one and now car revs to limit but then ecu picks up fault and limp mode is actived, limiting it to 3000rpm, turning ignition off and back on, clears it until its revved hard again
    even when revving, doesnt seems that smooth
    what could cause this?
    Nr Cardiff
    Get it to a VX dealer, pay them £20 and ask them to Tech2 it. That will give the fault code for the problem and should point you in the right direction mate.
    Feb 2006
    Guttedsville
    EGR Valve normally a prob with these.
  1. 2.2Dti
    By Gazz in forum Diesel Engine related
    Last Post: 24th May 2011, 12:44
  2. Will this fit my 2.2dti
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2011, 20:25
  3. Eml 2.2dti
    By Gortreck in forum Engine & Drivetrain
    Last Post: 3rd March 2010, 20:23
  4. its not too bad for a std 2.2dti.............
    By david.aka.judas in forum Gallery
    Last Post: 16th March 2009, 08:58
  5. 2.2dti, not GM?
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2007, 00:32
2.2 dti wont go above 3000rpm
