Results 1 to 2 of 2
Thread: Fan not working at higher settings?
    Oct 2009
    newport
    Default Fan not working at higher settings?
    Bit of a strange one. Started the car today and no immediate air con as normally happens, drove about 2 mins and the air con burst into life as normal. Again later in the day, stopped got back into the car 10 mins later and no fan but again started after about 3 mins of driving. However when ive gotten in the car tonight i've got no high speed on the fan at all?? The fan seems to be working on settings 1 and 2 fine-checked behind the pollen filter and it seems to be turning ok but maybe slighly whining? Any ideas guys?
    andy
    Oct 2009
    newport
    Taken apart glove box today and checked resistor which doesnt seem to be damaged or burnt (is the climate control version) and the motor seems to be spinning fine on settings 1 and 2 but almost seems to be stuggling when the fan speed is turned up? i tried alternating between demist and off and a few times it nearly blew at full strength for a few seconds then went back to normal? Any ideas or am i looking at a new fan? The only thing i noticed a few days ago was that it was squeaking slightly so i sprayed on some wd40-could this be causing the problem? any suggestions would be appreciated!
  1. Whould wheels higher car??
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2011, 14:11
  2. Cost of living getting higher
    By the_wave_rider in forum The 'Off Topic' room
    Last Post: 1st February 2011, 19:47
  3. higher or lower ?
    By signumboy in forum Styling
    Last Post: 28th February 2008, 12:04
  4. oh no its higher on one side
    By topline in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2006, 22:25
  5. Higher at the front!
    By Doug-SRidirect in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2006, 14:10
