Results 1 to 10 of 13
Thread: Advice Needed - Steering Wheel Vibration
    Cheltenham
    Default Advice Needed - Steering Wheel Vibration
    Hi All. Need a bit of help and advice on this one. Had a puncture repaired on the right front tyre a couple of weeks ago. The tyre had a new valve and balance, but at motorway speeds I was getting some steering wheel vibration (not bad but annoying enough). Thinking it was a wheel balance issue, I then had both front wheels balanced at a different place, but the problem is still there. I don't recall having this issue before the puncture repair.
    Has anyone come across this before or have any advice on things to check?
    Sodding Typical on Sea
    Did the rim get pushed out of true when you got the puncture as it may just have a small buckle throwing the wobble up to you when driving
    Cheltenham
    The tyre didn't actually go flat. It was just losing pressure over time. There was a nail at the bottom of the tread groove.
    preston
    Smile
    we've had a couple of similar threads to this recently
    try swapping front to rear and see if it goes away.
    i had real problems once with a new pair of goodyear eagles.
    balanced x4 times and still not right.
    in end put them on back and all was fine.
    must just have been unlucky
    Cheltenham
    Thanks for the tip. I'll give it a go and see how things turn out.
    Regular Member Exclusive BV's Avatar
    West Midlands
    Do you have the Vauxhall Structure wheels?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Foz
    our local tyre specialist balances wheels whilst still on the car allways works,find a dealer that has the equiptment.
    Cheltenham
    Forgive my ignorance but what are 'Vauxhall Structure Wheels'. I got the bog standard facelift sri wheels on my car.
    Quote Originally Posted by Fozman View Post
    Ask google - simples.
    http://www.carpages.co.uk/vauxhall/v...a-27-08-05.asp
    Cheltenham
    Well, the answer is no. I've got the sri alloys.
  1. Vibration through steering wheel
    By hothatch in forum Engine & Drivetrain
    Last Post: 1st December 2012, 20:58
  2. Steering wheel vibration/wobble
    By gibbon7000 in forum Suspension, Wheels & Brakes
    Last Post: 24th September 2010, 20:23
  3. steering wheel wobble/vibration
    By trucker in forum Insignia car chat
    Last Post: 3rd June 2010, 21:20
  4. vibration through steering wheel at 70mph
    By stef in forum Introduce yourself.
    Last Post: 2nd March 2009, 10:10
  5. vibration from wheels,steering wheel
    By steve.o in forum Suspension, Wheels & Brakes
    Last Post: 26th March 2007, 01:29
