Thread: temp gauge fluxuation
    glasgow
    Default temp gauge fluxuation
    1.9cdti 150 sri.
    just came back home after being on mway and happened to glance down while free wheeling upto a round about as in a very relaxed mood and temp was at 20 deg or so after just driving at 70mph seconds earlier. within 50 yards or so of normal driving again went back upto 80 which is normal for it.
    tried a little test, ran car upto 50mph and freewheeled it and after maybe 10/15 secs the temp went down to about 20 again i assume may have went lower but had to put it in gear again. i assume the water can't physically cool this quick so perhaps the sensor is faulty or thermostat is goosed?
    any tips on things to do guys or where i can check these things?
    p.s i had the car in for a new aircon condenser last week at stealer-related to this perhaps? i.e broken something?
    cheers
    glasgow
    little update-
    took the sensor connector off, cleaned and reconnected.
    took the car for a drive and all was normal again. maybe not quite seated correctly with the dealers fitting my new condenser last week???
    if it does go again i assume i will need the thermostat housing replaced?
    cheers
    Sep 2009
    Glasgow
    alright b ud where is the sensor plug
    PRESTON
    temp sensor is on the thermostat housing, which is under the vacuum pump. right hand side of engine as you look at it, near the big boost hose.
    Sep 2009
    Glasgow
    ta, anyone any pics
  1. temp gauge
    By studmuffin in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 15:59
  2. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  3. temp gauge
    By cow monkey in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2007, 16:22
  4. temp gauge
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2007, 23:58
