Results 1 to 10 of 13
Thread: V6 CDTi pulse/surge at 2800rpm
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default V6 CDTi pulse/surge at 2800rpm
    If I build up the revs slowly to 2800rpm (e.g. exiting a roundabout in 2nd gear) and then touch the pedal ever so gently I feel the engine surging up to approx 3000rpm.
    Is this normal?
    I'll test on mine tonight but I think I have also observed this sudden increase in revs through this range
    I suspect this is the power band for this engine, in the range 2500 to 3000 rpm
    However the majority of my driving is at the lower revs, at roundabouts I am rarely at more than 2000rpm
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I was preparing to give it the berries then. I usually drive below 2000rpm when I'm tootling along.
    Living in Cumbernauld I have access to quite a variety of roundabouts
    In order to recreate this, could you advise (speeds in mph please) :
    Typical road speed limit
    Typical entry speed, gear, and revs at roundabout
    Typical speed, gear, and revs on roundabout
    Typical speed, gear, and revs on exit of roundabout
    Most of the roundabouts are 40mph, 50mph, or NSL (70mph dual carriageway)
    I am usually in 3rd gear on entry and on exit
    There are also two roundabouts where I know I am in 4th gear throughout, but there are two where I have to use 1st gear!
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    You don't really need a roundabout to recreate this. Try accelerating slowly in second gear up to 2800rpm and then hold the revs for a few seconds. Then give it a bit more throttle, gently, and you should feel the surge to 3000rpm.
    Mine usually does it in 2nd and 3rd. Can't really feel it in any other gear.
    As above, I need to know what speeds you experience this
    I can then decide where is the best place to recreate this
    I will do this shortly, and have now printed this page out
    Here are my results for 2800 rpm to 3000 rpm
    2nd gear : 32 mph - 40 mph
    3rd gear : 48 mph - 55 mph
    4th gear : 65 mph - 70 mph
    This suggests it is the gearing
    Also at this rev range it is the maximum torque
    In the lower gears this results in greater acceleration, which the body can feel
    In the higher gears there is less acceleration, which the body does not feel to the same degree
    Equally, for those speeds I would be using 3rd gear throughout, entering a roundabout at 30 mph and exiting at 30 mph, then changing to 4th gear to accelerate up to 40 mph
    Driving in 2nd gear at 30mph, on high revs would not be recommended on this gear box!
    EVERYWHERE
    Please explain!
    As for the "surging" issue. I can't say that I've noticed anything on the wifes V6 that appears to be that noticeable.
    Maybe switching off the ECU and then switching it back on again (in the time honoured fashion) will clear any anomolies?
    I very rarely drive in 2nd gear above 3000rpm / 30mph to 40mphThis is the power band for this engine; not recommended for this gearbox
    EVERYWHERE
    You don't get on the "diesel tuning" forum much do you? LOL
    I've heard about the problems, but the anecdotal evidence to the contrary will always win through.
    Went out in the Vectra this morning and didn't notice any untoward surges at any point in the rev range. Used to get them all the time with the tuning box fitted, particularly when at low speeds in low gears.
  1. Sudden surge of power at 2k revs - 2.2 DTi
    By cont1204 in forum Engine & Drivetrain
    Last Post: 18th January 2011, 00:59
  2. Rattling noise over 2800rpm (CDTI 120)
    By rec in forum Engine & Drivetrain
    Last Post: 1st November 2010, 15:39
  3. Max 2800rpm in Every Gear
    By B1uenose in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2010, 13:48
  4. Pioneer HU Pulse
    By bluebirds1975 in forum Electrical & ICE (including SatNav)
    Last Post: 27th April 2008, 16:40
  5. Engine Surge...
    By Penfold101 in forum The 'Off Topic' room
    Last Post: 4th April 2008, 23:20
