Thread: Gearbox oil
    Mileage : 000
    Default Gearbox oil
    I was going to ckeck and possibly top up the gear box oil.
    What oil do I need to get for my 3.2 V6 5 speed manual gearbox.
    preston
    hi
    i replaced mine completly.
    i had stiff changes from 1-2 in cold and Vx reduced oil levels in gearbox from 3.2 to 2.4 litres in 2005 for the f40 box.
    So i did the same and bingo it cured it.
    I can't remember the exact spec but I seem to remember it being fully synthetic stuff
    there's a recent how to do
    http://www.vectra-c.com/forum/showthread.php?t=114193
    and some info from another post
    The F40 6 speed suffers from syncro problems with 3.2 ltrs so vx recommend you only put in 2.4 ltrs. This correct from the VX tis.
    Signum 2004...,Vectra-C 2004... Z20NET| Z19DT| Z19DTH| Y30DT| Z30DT,Z20NET| Z19DT| Z19DTH| Y30DT| Z30DT
    Complaint: Hard 1-2 shifting when transmission is cold, 2-3 shift when transmission warm.
    Cause: Design related.
    Production: The reduced oil level was introduced in production starting 08.05.07 with the following VIN:W0L0ZCF4871102355.
    Remedy:
    In case of customer complaint reduce oil volume from 3,2 to 2,4 liter.
    Note: If the shifting behaviour will remain unchanged we do not
    recommend a transmission replacement because the problem might reoccur
    since there were no relevant design changes since
    transmission-No: R05020418 (March 2005).
    good luck
    preston
    Sorry, misread i though you were on 6 speed box. apparently you'll be on the F35 gearbox so i'm not sure if the same applies to yours as the F40 as the excess oil affected synchromesh.
    all the same i'd pop to Vx and check what they suggest for specific spec of fully synth and if they reduced gearbox oil levels in the same way as for the F40
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Stick with Vx stuff, Ed
    Regular Member Jezzy's Avatar
    S.E
    Only the F40 needs the oil level reduced, not the F35.
    Mileage : 000
    Any one know the spec" and the part number then please.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Simply ask for manual transmission fluid for F35 gearbox. It was only 10€/L for my F40 about a year ago
    S.E
    Quote Originally Posted by ed taylor View Post
    Castrol SMX-S fully synthetic gearbox oil is at least as good as the Vauxhall stuff, available from Halfords.
    http://www.halfords.com/webapp/wcs/s...egoryId_165750
    Regular Member DaveW555's Avatar
    Cannock
    Vx part number is 93 165 290 and it holds 1.9 litres Ed. According to AutoData there isn't a level plug so you'll probably just have to completely change the oil.
    Mileage : 000
    Cheers folks for your replies.
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
