Results 1 to 10 of 15
Thread: dti engine change
    Jul 2010
    Birmingham
    Default dti engine change
    Hi. my car is a 2002 vectra 2.0 DTI, and the engine is knackered. i replaced it with a another DTI engine from a donar car, complete with the engine wiring loom, i did not swop the fuel pump over as the replacement engine was in good running order, when i tried to start the the car, all get is click noise fron the glove box side and the engine wont turn over.
    is ther any electronic items i need to change over from the donor car?
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    hi mate the diesel pump will need codeing to the car and to do that you will need the car pass from the car the engine came from.or you can swap the pumps over and do it that way then it will run.
    hope this helps
    Jul 2010
    Birmingham
    Hi thanks for the reply, i do not have the code my car, i have complete donar car at my disposal, it there any other electronic components i can change from the donar car with out having to change the fuel pump.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    you would need to change all electronic components to try and get it started ....would be easyier to swop the pump .../
    leicester
    Trim : Sri xp2
    Mileage : 100000
    Quote Originally Posted by driveryte View Post
    hi you can request the security code from vauxhall if you have registration of donor car alot easier than swapping pumps.
    Regular Member DaveW555's Avatar
    Cannock
    To get the security code don't you need the vehicle registered in your name with the v5 and additional proofs of address and photo ID etc?
    I'd change the pump matey its the easier option (although it would have been far easier to do it with the engine out) seeing as its already coded to your ecu.
    You can get the new pump code by-passed so it will work in any car if there's anyone in your area who can do it for you, then either keep it as a spare or sell it on, you should have no problems selling it seeing as them pumps are prone to failure.
    leicester
    Trim : Sri xp2
    Mileage : 100000
    Quote Originally Posted by DaveW555 View Post
    i got the security code with out the car being in my name.
    llanelli
    just did the same here with an engine swop
    vx told me no probs with log book ect to get sec code from donor car just wanted vin and reg and 25 pound ish
    i just changed the pumps over while the engine was out
    got nearly a compleete engine worth of bits now to sell of when i get the chance lol
    Cannock
    I thought they'd changed the rules on stuff like security codes etc to stop ringing, I'm trade and I cant even order some stuff without all the paperwork, I think number plates is about as much as they'll let me have now. Its a bit lapse on vx's part really, not saying that any of you have done it but if you had a motor stolen for the engine and they're just giving out codes left right and centre to any tom dick and harry it kind of defeats the object of having security codes.
    llanelli
    i just went into the local vx main dealers told them i am going to change the engines over and asked what i needed
    he replyed i need both donor and current car sec code
    i said i have no idea about donor car as it was being broken
    give me the reg and vin and i can order the code for you he said
    i did say the car is not in my name on log book or even have 1
    wasnt bothered he was just happy to help lol
  1. engine change help
    By ros46si in forum Engine & Drivetrain
    Last Post: 7th October 2012, 21:48
  2. How often do you change your engine oil?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2011, 13:32
  3. change my engine!!!
    By bedo13 in forum Tuning
    Last Post: 28th July 2010, 23:50
  4. had engine change
    By Nojustice in forum Engine & Drivetrain
    Last Post: 13th January 2010, 14:20
  5. engine change
    By yadziyad in forum Diesel Engine related
    Last Post: 22nd May 2009, 20:38
vectra engine change
can i get securty code for diesel pump with reg or vin number
