Thread: no power
    Jul 2010
    bishop auckland
    Default no power
    i was driving my car last night and all of a sudden it lost all power and cut out wont start now. i have been told that the fault is with the crank sensor. does this sound right.
    if so does anyone no how to replace the crank sensor
    cheers
    Jul 2010
    bishop auckland
    i have got to this point but can now see that the crank belt has snapped but cant get it out i am guessing this is causing the car to not start will it have caused any more issues
    Regular Member Jezzy's Avatar
    S.E
    That's the "timing" belt - it makes sure that the valves open and close at the correct "time", i.e. when the piston isn't at the top of the cylinder. As the belt has snapped, it's highly likely that the valves and the piston will have collided in at least one cylinder. To find out what damage has occurred you will have to have the cylinder head removed and that will expose the valves on the underside of the head and also the pistons in the engine block.
    Jul 2010
    bishop auckland
    is it hard to fix
    Northampton
    Engine : A20DTH
    Mileage : 88000
    possible new engine
    preston
    ouch
    how many miles had you done?
    belts should last on 1.9 cdti 150 for 10 years of 90000 miles according to Vx....
    having said that i got mine changed at 82000 and good job as it was not far from failure
    what engine are you running. i'll check for you when they suggest changing it.
    if it dies before that point i'd reckon you have a good case to take them to task for premature belt failure.
    Jul 2010
    bishop auckland
    its a 1.8 elegance done about 85k i think
    london
    timing belt snapped.
    you will need new head if you have tools and balls you can do it your selff
    EVERYWHERE
    Are the valves 'interference' or 'non-interference' with regards to the pistons on the 1.8's ?
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 7th January 2010, 17:50
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
