Thread: fitting new brake lights...
    doncaster
    Default fitting new brake lights...
    hi guys, as the title says i have to fit sum new lights and need advice. i have 2 out, one on each side at the back, i have a vec c estate, one is the outer light on one side, and the other is the inner light on the other side. How do i go around it in laymans terms, and do i need any special tools. Are they the same bulb, and has anyone got a part no., and maybe a recommended place to get sum, or shud i just bite the bullet and go to the stealers parts counter.
    cheers
    admob
    doncaster
    just found the part no's in the how 2 section, also found fitting info for a signum, will my vec be similar..
    cheers..
    Regular Member Jezzy's Avatar
    S.E
    You'll need the brakelight rewind tool.....
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    To replace the brake lights in an estate.
    You need to remove the light panel. Looking into each rear corner you will see three grey trianguler knobs. Unscrew these and the light panel will come off. Remove the electrical connector and then replace the bulb. Fitting is a reverse of removal.
    Easy
    The reason you have odd brake lights is that the vectra compensates for the broken bulb. You only have one bulb out. You just have to work out which one.
    Only tool needed is a hand.
    West
    As above & no need for a brake rewind tool lol...
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    to remove the cover on the bootlid to come to the lights in the tail gate,
    you have to remove the screw in the inside handel, and on the outer edge you will need to remove the clips before just pulling..
    doncaster
    cheers guys, ive had a quick look, and replaced the duf one in the tailgate, and it still doesnt work, so im leading to believe that it is ok, and just not working due to the reason stated above.. ive had a look at the one in the corner, i can only see one grey knob to upscrew on the inside, do i have to remove any interior trim to get access to the unlocking screws, if so how, i know sum trim just pops out, but others screw out, and i dont want to damage anything... thanks in advance...
    ps, on the signum pics on how 2, it just states, remove the stowage door, and unscrew the 3 screws, but the piccy seems to show more of the bones of the car, as if sum trim has been removed as well. ???
    Engine : 2.2 Direct
    remove the 3 srews, then you can take your light out (the hole light) then theres 3 srews more to get to the bulps itself.
    doncaster
    all sorted, thanks guys for the help. bizarrely tho, one of the 3 grey triangle screws was missing, surely u wudnt forget to screw all 3 back on after doing a bulb change..??
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. fog lights fitting
    By Fraz in forum Electrical & ICE (including SatNav)
    Last Post: 21st February 2012, 12:32
  3. Fitting fog lights
    By blackbeauty in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2011, 11:17
  4. Fitting xenon lights?
    By tom_p_2000 in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2009, 20:56
  5. brake fitting
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2008, 20:09
