Thread: Fob battery change
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    Default Fob battery change
    Hi, changed the battery in the main key fob today but now the fob won't unlock the car, tried unlocking and then locking with the key as Haynes says to sync the fob with the car but that doesn't work, I can unlock the drivers door with the key but as soon as you open the door the alarm goes off, any help greatly appreciated, Gaz.
    Fob just needs synchronised with the car again. When you unlock the car with the key, and the alarm goes off, just stick it in the ignition and turn it. Car should start and alarm turn off.
    Take it out and try it from the fob, should work. If not then you may need to insert the key back into the ignition and press the lock, or unlock, key to sync it IIRC.
    Jan 2010
    Cornwall
    Yep your right, oh well it was different getting the bus to work today lol, Cheers, Gaz.
  1. Battery Flat after thermo change?
    By unknownbullet in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2013, 18:00
  2. outside temperature display's "F" on the display after battery change
    By Philhammond2004 in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2012, 19:12
  3. Key Fob - Battery Change
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2010, 22:10
  4. Key Fob Battery Change?
    By parapaul in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2008, 16:22
  5. Key Fob Battery Change
    By yorkshireborn in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2008, 14:39
vectra c key fob battery change
VECTRA C SYNC AFTER BATT REPLACE
