Thread: z18xe burning oil or head gasket??
    Events Manager & Moderator jon1.9cdti's Avatar
    Swanley , Kent
    122 Post(s)
    Vehicle : Sports Tourer
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Default z18xe burning oil or head gasket??
    Hi all, my car is using a lot of oil ( 3 litres) in under 700 miles, i originally thought it was rocker cover gasket as oil was leaking down onto manifold.
    IS IT PISTON RINGS?
    if you give the car some stick you can see some smoke in the air behind and if you get the revs high about 5000-6000k while stationery there is a lot of smoke,,,,
    IS IT HEAD GASKET?
    When you first start the car in the morning there is momentarily a misfire until it clears itself and will run fine all day , i had similar on my old vectra b and that was head gasket on piston number 3 , there is when you rev the car while stationery droplets of oil coming out of the exhaust
    A BIT OF HISTORY
    i have only had the car 3 weeks and purchased it with 77,000 miles, at 76,000 miles it had a complete reconditioned head ,head gasket, cambelt and water pump (cambelt snapped apparently), at the same time it was apparently serviced with new plugs , oil and filter.
    due to the fact it had a recon head i have discounted the valve stem oil seals and also there is no smoke on start up,
    i will be fixing myself and kinda hoping it is head gasket, it would not surprise me really as the guy that did the work strikes me as a bit of a cowboy as i have found 2 bolts missing from alternator, 2 exhaust manifold studs missing and 1 nut missing from manifold, loads of jubilee clips undone etc
    Regular Member DaveW555's Avatar
    Cannock
    Head Gasket sounds good to me but to be doubly sure while the head is off whip the pistons out and hone the bores and put some new rings in, makes sense while the head is off.
    scotland
    valve stem seals mate , prob got a bent stem or two
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    take the head off and check for coke around the bores at the top of the piston stroke. if clean its top end, if coke lip its bottom end
    Swanley , Kent
    122 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Quote Originally Posted by gsxrster View Post
    It's had a recon head ?
    Swanley , Kent
    122 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Quote Originally Posted by DaveW555 View Post
    Either way the head has to come off, I'm thinking if I do a full strip down I may as well do a bottom end rebuild
    Swanley , Kent
    122 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Quote Originally Posted by mattv6diesel View Post
    I'm having the head off tomorrow after a quick compression test, and I will bear that in mind
    Swanley , Kent
    122 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    i stripped the engine down , and will be stripping bottom end tomorrow, i am going to hone the bores and re-ring the pistons as im certain this is where the problem lies ,
    im in 2 minds whether to change the big end bearings while im down there as it makes sense while im there, or do you think im just wasting money ?, i have stripped and repaired many engines but not once have i ever touched the block, is there likely to be any serious consequences or complications if i change the bearings?
    anyway a few pics
    this is the state all of the pistons were in
    the head was atrocious (when you consider it was only fitted 1500 miles ago ) allegedly and as you can see i am part way on cleaning
    here are the pistons after having a clean prior to me taking them out tomorrow ( i thought they would be easier to clean in situ)
    Cannock
    just check the shells when you take the big ends off, if there really clean and sliver then they'll be fine to go back in, if theyre scored or brass is showing through they need replacing, make sure the caps stay with the right rod and the pistons go back where they came from. have you got all the torque settings or is there any you need?
    Swanley , Kent
    122 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    the only torque settings i need are for the conrod caps as they are the only ones i cannot find,
  1. Head Gasket gone????
    By ussy2012 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2012, 16:36
  2. Head Gasket help please !!
    By mark_647 in forum Engine & Drivetrain
    Last Post: 4th April 2009, 11:57
  3. 3.2 Head Gasket Gone/Going ??????
    By gsi32 in forum Engine & Drivetrain
    Last Post: 15th June 2008, 21:46
  4. head gasket???
    By coylo5 in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2008, 23:04
