Thread: Lambda sensor "size"
    Jul 2010
    Yorkshire
    Default Lambda sensor "size"
    What size spanner will I need to undo the lambda sensor on my 3.2 vectra please? I'm going to have to go and get a new spanner set and want to make sure that i have the right size!
    Thanks!
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Think they are 22mm
    Jul 2010
    Yorkshire
    Thanks alan
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Their actually a specially shaped socket. Bought 1 to change mine over a year ago. tip for you spray with wd40 a day b4 you intend to do the job and remove when engine is warm (not hot)
    Nov 2007
    weymouth, dorset
    The socket or o2 sensor socket is only needed if the access is tight, As its the front bank he needs to change a spanner should be sufficiant,,.
    Regular Member DaveW555's Avatar
    Cannock
    They actually aren't a special shaped socket its just a normal 22mm with a slot cut in it for the wire to stick through, as long as you unplug the wiring first when you undo it and last when you put the new one in you should be sweet so as not to twist the wiring up too much and possibly damage it.
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. Parking sensor with "trailerhook"
    By staverh in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2010, 20:41
  3. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  4. "Goodbye" grey sky, "hello" blue !
    By FIL 4822 in forum General Chat
    Last Post: 24th October 2008, 12:34
size socket for lambda sensor vectra
vauxhall vectra c lambda socket
what size die tap lambda sensor vauxhall
lambda sensors on vectra 3.2 forum
lambda vectra c 1.9 cdti thread size
