Thread: What amp to get for my pioneer 12"
    leicester
    Default What amp to get for my pioneer 12"
    Ive got a juice 2400 amp at mo and a 1000w 12" pioneer sub. The sub cuts out when i think the amp is getting overheated. Then it comes back on again...so i think its time for a change of amp.
    But what amp to go with the sub?
    Hearing contrasting things ...also mono block or 2 channel...whats the major difference?
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    What Pioneer sub is it? Are you running it in a sealed,ported or vented box?
    Mono blocks are primarily for running subs through a single channel, 2 channel subs run speakers through 2 or 1 channel so are a bit more versatile.
    leicester
    sealed box..standard u knw. no fancy vents or owt...jsut bog standard..sounds mint...got introduced to a vibe sub ealirer this week at an audio shop , proper fancy sub. with vents etc...but nowhere near better than mine...im going to be changing the wiring aswell, but got told that dnt make a hell of difference neway...so amp i think it is...
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Just put a fan on the amp, thats whats cutting out, not the sub. Something like this Fan here. Just connect it to the switched live and earth on the amp. I had the same issue years ago, I added 2 of these fans blowing across the heat sinks of the amps, works a treat. If you do decide to change the amp get a dedicated mono sub amp or at least a 2 channel amp that can be bridged.
    Maidstone, Kent
    Might be worth investigating why the amp is overheating. Where is it mounted? Is it upside down or enclosed?
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. vrx 12" sub and pioneer amp
    By vectragsi3.2 in forum General items for sale
    Last Post: 3rd July 2009, 14:00
  3. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  4. Pioneer Headunit 7" Screen, TV Tuner, CD Changer & PS2
    By joe2187 in forum Parts for sale
    Last Post: 1st May 2009, 12:07
  5. Pioneer 10" Sub
    By carl bear in forum Parts for sale
    Last Post: 13th July 2007, 21:46
