Results 1 to 3 of 3
Thread: P1112 Swirl flaps
    Mar 2010
    n iRELAND
    Default P1112 Swirl flaps
    Vectra 2.2i - eng mang light came on. I checked it with meter and cleared it- I have been doing this for a few months - every 1/2 days the light comes on again. Took to the dealer they diagnosed stock swirl flap - £400 + another £200 to fit them. That was a week ago - the eng mang light has not come on since. Should I proceed with the suggested repair. The car runs fine even with the light on and does not lack power - 41K on the clock. Any advice would be welcome.
    Regular Member mattv6diesel's Avatar
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Year : 2008
    the actuator rod gets stuck. unlike the 1.9's the flaps are just the inlet gaskets. bit fiddly to get the manifold out though worst bit. up to you doesn't bother you then don't worry might sort the bit getting stuck on its own
    Regular Member mikesri2.2's Avatar
    Jun 2009
    cheshire
    had mine on for a while due to swirl flap error.took it to local garage which they sprayed lots of carb cleaner in manifold to clean the rod.
    worked a treat not been on since
  1. P1112 swirl valve
    By steve1975l in forum Engine & Drivetrain
    Last Post: 13th December 2012, 12:56
  2. Swirl flaps
    By McLovinH in forum Engine & Drivetrain
    Last Post: 21st August 2012, 06:50
  3. swirl flaps
    By justin32 in forum Engine & Drivetrain
    Last Post: 7th January 2012, 18:34
  4. Hi CO and Swirl flap code P1112
    By silflex9 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 11:44
  5. Swirl Flaps & DMF
    By GenVectra in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2009, 07:56
