Thread: CDTI fuel filter crash box retaining clip
    Fife
    Default CDTI fuel filter crash box retaining clip
    Going by the Haynes manual, before I can remove the fuel filter from the crash box, I have to use a screwdriver to depress the retaining clip. Where on earth is this clip and how the hell do you depress it?
    I feel completely daft asking this but its doing my head in!!
    Dunno mate - I spent an hour searching for it once putting the screwdriver in all sorts of places and couldn't find it anywhere. In the end I changed the filter in situ by 'persuading' the securing ring on top to rotate off...
    preston
    Exclamation hmm
    do they not mean retaining blue clips on the fuel hose lines going into the filter? you can use a screwdriver for this being very very careful. Vx have a tool for this
    so
    beware the retaining clips. don't break the black tabs ( front and rear ) that hold them in or its a £100 for a new filter housing from Vx
    remove electrical connection first
    My filter housing just comes out of crash holder with careful lifting + wd 40.
    Once out I drain the fuel from the bottom of the housing and retighten the screw
    then use an oil filter wrench and flexible rubber strap device to move the top of the filter housing from the bottom.
    then take the filter out
    replace filter
    replace o ring with a smear of diesel and retighten.
    put fuel hoses back in
    then drop into retaining crash holder
    prime the filter X 3 times by turning key to first point without turning engine over.
    you'll hear lots of gurgling but it will work
    then once done
    fire her up
    check your seals to make sure no leaks as its under pressure ( a lot )
    thats it really
    if you have the right tools its quick
    if not its a pain
    and once again beware the retaining clips. don't break the black tabs that hold them in or its a £100 for a new filter housing from Vx
    be warned
    Fife
    Sorted. Touch of WD40 and I managed to wiggle it out of the housing.
    Cheers.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi dittohead
    as mparks says it is the fuel lines that hayes refer to
    preston
    Default glad to be of service
    cheers
    i'm gonna post this as a how to when i change mine next
    just forgot to take photos last time
    glad it worked.
    preston
    Default extra warning
    by the way
    never try to remove the filter housing head whilst its in the crash box
    you'll lose the crash box mountings
    the filter housing is supposed to be 30nm tight but it feels more like 100nm
    cheers
    PRESTON
    how 2 would be good, alot of people seem to ask about fuel filters often on the forum.
    Bristol
    Vehicle : CDTI 150
    The retaining clip is at the rear (nearest bulkhead) of the crash box.
    You can use a large flat bladed screwdriver inserted between the back of the filter housing and the crashbox then you need to push the top of the screwdriver towards the bulkhead at the same time wiggling the filter housing, can be a real pain.
    I'm doing a CDTI diesel filter change on Thurs and will take my camera along if no one has posted a how 2 before then.
  1. Fuel filter crash box removal mod - 1.9cdti engine
    By alcutler in forum Engine & Drivetrain
    Last Post: 22nd May 2011, 23:19
  2. Help - Headlamp Retaining Clip!!!!
    By watchman in forum Electrical & ICE (including SatNav)
    Last Post: 3rd April 2011, 23:18
  3. break pad retaining clip
    By kirky2k4 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 20:12
vectra fuel filter clips
fuel line clips vectra
vectra c removing fuel filter from crash box
