Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: 2.8v6 spark plugs.....has anyone changed
    WGAF#5
    Default 2.8v6 spark plugs.....has anyone changed
    there spark plugs themselves ???
    or am i going to be the first one to attempt this "at home"
    has anyone got access to TIS for removal refit instructions?
    i want to get mine changed ready for next weeks rolling road
    so any assistance - or shall i make a HOW (not) 2
    thanks
    Dez
    Regular Member PORKBALLS29's Avatar
    Epping
    I'm getting mine serviced Monday Dez ready for the R/R sat too. I didn't fancy attempting it my self. Does the manifold have to come off to take them out?
    WGAF#5
    i dont know yet ...... thats what i'm hoping to find out before Sunday
    Epping
    I dont think its gonna be that straight forward tbh. But i'm sure a man of your calibre will sale through it.
    Mileage : 000
    If it is like on the 3.2V6 it is not a five minute job.
    WGAF#5
    Quote Originally Posted by ed taylor View Post
    autodata says 1.5 hours - but no details on whats required
    Mileage : 000
    Yep 1.5 hours sounds about correct. Have you looked at the 3.2 how 2. It might give you some idea?.
    WGAF#5
    Ed 1.5 not 12.5 lol
    and yes i did
    - so i'm hoping for some similarities to be present - but you know they wont be
    Mileage : 000
    Ed 1.5 not 12.5 lol
    and yes i did
    Dyslexic keyboard. I have corrected it.
    Regular Member Jezzy's Avatar
    S.E
    This is how to do it on the Saab 9-3 2.8, can't be that different on the Signum:
    1) Remove engine cover
    2) Detach the ground cables and unplug the connectors of the engine control module
    3) Remove the engine control module with mounting. The lower hole of the mounting is slotted.
    4) Unplug the atmospheric pressure sensor connector.
    5) Remove the cable duct from the plate bracket
    6) Remove the plate bracket from the intake manifold
    7) Detach the brake vacuum hose from the intake manifold
    8) Remove the holder and check valves for crankcase ventilation and tank bleeding
    9) Unplug the ignition coil connectors. At cylinder 4, the ignition coil must be loosened and lifted slightly in order to unplug the connector.
    10) Remove the ignition coils
    11) Remove the spark plugs.
    12) When replacing plugs tighten to 28 NM (21 lb ft)
  1. Spark Plugs were wet
    By xoborp in forum Engine & Drivetrain
    Last Post: 7th January 2013, 21:59
  2. Spark plugs
    By telstar in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 20:36
  3. Spark plugs
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2010, 20:28
  4. v6 SPARK PLUGS
    By vecgsiboy in forum Engine & Drivetrain
    Last Post: 7th July 2009, 07:31
  5. Has anyone changed spark plugs on a 2.0T?
    By Duncan in forum Engine & Drivetrain
    Last Post: 26th February 2007, 10:58
